Results 1 to 13 of 13
    Jun 2018
    1st Road bike setup/upgrades
    Have lurked for quite awhile and have found the forum posts informative and enjoyable. Me early 30s 6'1" 200 33.5 inseam previously road mountain bikes current ride a dual sport hybrid for mostly neighborhood rides with kids in trailer or trail-a-bike. Had contemplated picking up a road bike to log some more miles etc. Hit the local bike shops and Craigslist after reviewing the forums, multiple Specialized dealers, Trek, Giant, REI, and a Performance bike in town. Ran my numbers through the competitive cyclist website and was mostly searching for a decent used alloy 58cm frame with 105 spec components. Sat on a few new ones but wasn't quite ready to plunk down the $1200-$1500 quite yet.
    Was out pulling the 4yr old on the trail-a-bike around the neighborhood garage sale this weekend and saw Specialized road bike a few blocks over. 56cm frame 2009 Allez Sport, 5600 105 Crank,F/R Der, Mavic cxp22 rims upgraded with 23mm gatorskins. He had the stem flipped 90mm +16deg. Rode well shifted well and couldn't turn it down for the price $50.... Fit doesn't appear to be bad.
    Here's where i'm at with questions
    Will probably order a longer stem 110 or 120mm to stretch the cockpit and probably decrease angle from +16 to 10 or so. Raised the seatpost and moved saddle back.
    Brakes are lackluster alloy dual pivots. Do i just slap some koolstopps in (unsure of size) or grab a set of 5600 or 5700 used 105 brakes for 40-50 off ebay, or get a new set of 5800 105's for $75 or so?
    Will be heading to the local bike coop to work on tuning it up will probably replace brake cables possibly shifter cables and check chain and degrease it.
    Pedals had a ugly set of alloy platform MTB pedals. Was planning on picking up a set of SPD shoes (MTB style) and some clipless pedals debating A-520's M-530's or possibly some Candy1's or the new Shimano ED500 dual side touring pedals.
    Have a Performance bike in town to grab some jerseys and bibs or shorts. Any Recs?
    Oct 2017
    It's generally not a good idea to put a lot of money into a used bike like that. Especially if there is a chance it's not going to be a good fit (physically) in the long term.
    My suggestion would be, if it's in decent riding shape, just ride it like it is, and save your money for a new bike when you are ready.
    Performance Ultra shorts and bibs are decent quality for the price. I'm not a big fan of the new model years graphics, but I have a few older ones that still make the rotation once in a while.
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    A bunch of people here may crucify you for fit issues buying a 56 at your height but I agree it may be worth playing around with for $50. If it doesn't work out maybe you can actually turn a profit on it. Good luck!
    BTW for time being I wouldn't bother with the brakes. Not a bad idea to do the cables and housing, and check the handlebar for corrosion when you take off the bar tape. You can probably find a good deal on a stem. But I wouldn't be surprised if you didn't ride this long before you want to upgrade, and you were already planning a substantially bigger budget so save it for the next ride...
    Dec 2005
    New cables/housing and properly adjusted indexing is money well spent.
    New brake pads are a very good and cheap idea to see if they improve braking. Wait until the new cables/housing are installed to see if braking improves. Then pads. Last resort new calipers if you think the braking is that bad.
    Regarding stem length and angle...no advise other than comfort is king. Try to resist any specific online advise. Everything will feel comfortable for the first hour. If your fit matches you're flexibility/body/ability then you should remain comfortable indefinitely. If fit doesn't match then the bike slowly becomes intolerable.
    No specific advise on short/bibs brand as they are so personnel. This, like shoes, are an area to not worry about money imo...You do want to size them tight enough that the chamois/pad doesn't move around but not too small that the pad is not covering areas designed to cover. You want more dense pad v. soft and squishy. Antimicrobial and breathable.
    Russian Troll Farmer
    Sep 2016
    $50??!!! Was it stolen? Is the frame cracked? The components alone are worth at least $100.
    "L'enfer, c'est les autres"
    Jun 2018
    No, older gentleman in the neighborhood. I live in a decent subdivision. Community garage sale weekend, put it out just to clear garage space. A bit dusty with a bit of chain grime. He and his wife have nice matching high dollar Gunnar trekking bikes that they explore on.
    Jul 2018
    I would focus on the issues that make the bike fit you better, and that's pretty much it. After you overcome those issues, and if it fits properly, then drop a few bucks here, and there as you see how the bike performs.
    I am 6'0", and ride a 58CM framed road bike, but for $50 I would have given that 56 a shot also.
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by Pilot321 View Post
    I would focus on the issues that make the bike fit you better.
    This. The first thing I would do is have your bike shop check your fit. The best money spent would be to have them put you and your bike on their trainer, watch you pedal and make adjustments to tweak your fit just right. This will increase your enjoyment of the bike more than anything else and may prevent repetitive use injury down the road.
    New cables and housings are a good idea too. Check tires and have the shop check your frame for cracks.
    Other than that, leave it alone and enjoy the ride.
    What the what???
    Jul 2009
    Yeah, that was a helluva deal.
    As others have said, start with safety, then focus on fit. Once you’ve taken care of those you should still be right-side up on the deal. Ride it till the wheels fall off and save your money for the next step in your new-found addiction.
    Sent from my iPad using Tapatalk
    The Law of Headwinds states: If the ride out is easy... wait.
    pmf
    pmf is offline
    You've got relatively short legs for someone of your height, so a 56 cm frame might not be that bad of a fit height wise. You probably will need a longer stem -- 12 or 13 cm. Stems are cheap and easy to swap out.
    Clean and lube the chain and consider some new tires. If it shifts OK, I'd wait on the cables.
    Jun 2018
    Thanks for all the suggestions. Have a bit over 100 miles on it the last 2 weeks. Cleaned the drivetrain chain stretch just over 0.5%, swapped a 120mm stem in for the 90 all of $25, feels better along with saddle height and setback adjustment. Ordered new stainless cables/housings, bar tape, some koolstop pads and an ultegra chain for about $70 total from Jenson.
    Grabbed some elite bibs and shirts from performance and swapped the 500g each flat pedals for some a520 touring pedals. I'm enjoying it so far.
    Will swap the cables this weekend, shifts well, just read too many issues with getting broken cables out of 5600 brifters if they shred so I'll just be proactive.
    May 2014
    Quote Originally Posted by R00K View Post
    ........ just read too many issues with getting broken cables out of 5600 brifters if they shred so I'll just be proactive.
    Check early, check often.
    Sep 2011
    Congrats, enjoy it man! It sounds like a good deal. I second those that say keep investment to the minimum for the moment (at least until you know you plan to keep it for a while) and invest in a fit session when you can. A good fit session not only increases comfort, it can also help you avoid injuries.
    Every climb has its end, for verily with difficulty there is relief...
  1. Replies: 15
    Last Post: 04-26-2011, 03:10 PM
  2. Cross bike setup vs Road bike setup
    By Salsa_Lover in forum Cyclocross
    Last Post: 07-31-2010, 10:00 PM
  3. mtb setup vs road setup
    By bauerb in forum General Cycling Discussion
    Last Post: 04-06-2006, 10:28 AM
  4. Switching Road setup to TT setup
    By Clark in forum Components, Wrenching
    Last Post: 05-11-2005, 04:11 PM
  5. Trainer bike setup vs. outdoor bike setup??
    By 10kman in forum General Cycling Discussion
    Last Post: 05-12-2004, 12:34 PM
