Results 1 to 11 of 11
Thread: First Bike.
    Apr 2018
    First Bike.
    I got on a bike for the first time in more than 25 years and was hooked. I spent last summer on a borrowed mountain bike that drove like a bus. Now I want to move onto a road bike (after participating in my 1st triathlon also on a borrowed bike). However, I don't want to drop too much money on my 1st bike. I saw a used Fuji Roubaix 1.0 (2010) for $550cdn. Assuming it's in good condition and assuming I can talk down the price, would this be a good choice? Or should I go into the $1000cdn range for a new Specialized or Giant?
    Reputation: Lombard's Avatar
    May 2014
    Always test ride before you buy. Does it fit? What is your height and inseam? What size is the bike?
    Fit is probably.....no, not probably, it IS THE most important thing to consider when choosing a bike.
    A bike that fits you correctly will make you more efficient than an ill fitting bike. It will feel good and make you want to ride.
    A bike that does not fit you correctly will eventually hurt you and may cause a repetitive use injury. If you hurt when you ride, you will lose interest in the sport.
    Brand is not that important. There are many great bikes from brands such as Cannondale, Trek, Specialized, Giant, Jamis, GT, etc. Fuji is more budget oriented, but definitely not a "cheap" brand like Schwinn, Mongoose or Huffy.
    Sep 2011
    Quote Originally Posted by JohninMtl View Post
    Going either way can be a logical choice depending on what your priorities are and plenty of us have tried both. These days, I am more in the camp of, if you can afford new, why not do that, get a free fit session, and start building a relationship with a shop in the process? Just my thoughts though.
    Every climb has its end, for verily with difficulty there is relief...
    Apr 2018
    Thanks. I should pop into a bike shop and get fitted.
    Apr 2018
    I was told by a bike enthusiast I play hockey with that anything less than 10 gears is a bad idea. That seems excessive for a novice rider and given the solid reputation of Claris, unnecessary. I appreciate your advice and will follow it. Thanks.
    May 2014
    Best idea yet!
    I don't know what to make of this statement. 10 or 11 gears will give you closer gear spacing than 8 or 9 gears. 9 is plenty unless you are racing. On a Synapse Sora, you get a Sora drivetrain (a step up from Claris) 9-speed 11-34T cassette:
    https://www.cannondale.com/en/USA/Bi...ntid=undefined
    If you want 10 speeds, you will need to go up to Tiagra which adds $300:
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    Price seems way high.
    https://www.bicyclebluebook.com/Sear...81&model=62548
    Food for thought
    One advantage of buying an entry level used bike, is if you don't like it, you're only out a couple hundred bucks. And you can likely re-sell it and recoup all (or most) of your money.
    If you buy a $1000 new bike and don't like it, you're pretty much going to be out 40-50% of your investment when you try and sell it.
    Yes bike fit is the #1 priority. But not all bike fits are equal or even remotely adequate. Many shops, especially on a beginner buying an entry level bike will give you a 5min eyeball fitting and send you out the door. If I had a $1 for every time I've seen that happen, and the rider still on the wrong size, I'd have a lot of $1's.
    Reputation: JCavilia's Avatar
    Sep 2005
    Best idea yet!
    All well said. Categorical statements about what's acceptable are a little silly, since the gearing you need depends so much on where and how you ride. A lot of us here started riding on the road when "10-speed" meant 2 chainrings and a 5-speed freewheel. The 9 cogs on my road bike are plenty for my hilly rides, and I do a lot of my flatter rides on fixed-gear bikes with only a single gear combination.
    That Fuji, IF it fits you and is in good condition, could be an excellent first road bike, and you might ride it for a long time.
    Happy riding.
    Have you ever been to Electric Ladyland?
    May 2014
    Quote Originally Posted by JCavilia View Post
    My bike as a teenager had a 5-speed freewheel with a single ring up front. Though where I rode then was mostly flat and my body was much younger. I would say 2x9 is plenty adequate.
    Key words here.
    Sep 2011
    Food for thought
    In the spirit of providing a full picture for the OP, I just want to point out that there are a number of brand new road bikes out there these days that can be purchased for significantly less than $1000. The Fuji Sportif, Giant Contend, Trek Domane AL, and Specialized Allez alloy are few that come to mind. Some are close to the price of that used bike. Why not have your cake and eat it too?
    May 2014
    Jamis is also worth looking into. The Aluminum Ventura with Claris and the steel Quest with Claris are both $650.
    performanceroadbikes
  1. first bike, first post, first questions
    By bizarrius in forum Beginner's Corner
    Last Post: 08-20-2012, 07:32 AM
  2. Replies: 8
    Last Post: 06-06-2012, 02:55 PM
  3. First bike, first thread, first pic
    By double_b in forum Beginner's Corner
    Last Post: 07-18-2011, 12:05 PM
  4. Replies: 44
    Last Post: 05-31-2011, 02:20 PM
  5. First ride, first pain, first post
    By Beethoven in forum Beginner's Corner
    Last Post: 07-29-2005, 07:58 AM
