Results 1 to 11 of 11
    Apr 2013
    Fuji Sportif 1.1 vs Raleigh Revenio 3.0
    Hello,
    I'm shopping for a new bike and these two are at the top of my list. The Fuji is equipped with Tiarga and can be had for $900 while the Raleigh has 105 and goes for $1200 (plus the $50 rebate). My gut says to save the money and go with the Fuji (I'm not convinced that I would notice a significant difference between the two groups), but are there other specs that might make the Raleigh worth the extra $250? For example, the Raleigh has 105 brakes while the Fuji has Ovals (I think). What about the BB or rims?
    I haven't yet taken the Raleigh for a test ride, so this is assuming both bikes fit me well and that I like them equally.
    Links for comparison:
    Fuji Bikes | ROAD | ENDURANCE | SPORTIF 1.1 C
    Raleigh Bicycles Revenio 3.0
    Thank you!
    Mar 2013
    IMO you should test ride both bikes, first. If one feels any better than the other, after riding each for a couple of miles or so, then get the one that makes you feel better.
    Look for your body's physical comfort and the ease in shifting. Make certain that any difficulty in shifting is due to mechanical complexity, and NOT due to any cycling inexperience.
    If one bike feels just as good as the other then only get the Raleigh, if you can truly afford it. Otherwise, the Sportif would be a great alternative.
    May 2012
    Quote Originally Posted by Bap the Baker View Post
    Hello,
    Thank you!
    it i so odd as i am look at these too. I think a part of it has to be how immune are you to upgratis.
    if oyu are ok with the Tiagra setup the Fuji is as low as it gets
    Apr 2013
    I guess it's the brakes that are making me hesitate. If I were to get the Fuji and became unhappy with the existing set, upgrading to 105 would be at least $100. Then price difference would be $150 or less and I would probably wish I had gone with the Raleigh from the beginning. Any thoughts on that? Thanks again.
    Mar 2013
    It would be worse, if you became unhappy with the Raleigh brakes....
    May 2012
    Why the brakes?
    Apr 2013
    Let me try to rephrase: Both bikes are within my budget. I would probably go with the Fuji to save $250. However I'm afraid that the no-name brakes will make want to upgrade (down the road). To buy front and rear 105s would cost at least $100 if not more. At that point the price advantage of the Fuji has been greatly reduced. Keeping that in mind, what I'd like to know is are there other components (apart from the drivetrain) that are most certainly better on the Raleigh that close that gap even further? Should I go with the Raleigh (assuming I like it once I take it for a ride) to avoid potential buyer's remorse? Or am I over-thinking this and should take my $250 and run?
    Cycling induced anoesis
    Reputation: PJ352's Avatar
    Dec 2007
    Any fit differences aside, I think there are other (more important) differences between the bikes than the brakesets. Get KoolStop pads and you'll think you had 105's.
    For instance, the Fuji has low spoke count wheels (20/24h) - not the best choice for a heavier rider. Also, the Fuji has an Oval crankset, the Raleigh Shimano.
    As far as groupsets, 10 speed Tiagra will (IMO) easily meet any recreational riders needs.
    Again, fit (and test ride) preferences aside, I think rider weight should play prominently in the decision.
    Mar 2013
    Quote Originally Posted by PJ352 View Post
    +1
    Well stated, PJ!
    May 2012
    Do note that this model of the Revenio uses the Tiagra cassette
    Apr 2013
    Test ride both, you'll like one better.
    You're better off spending $1,200 than wasting $900 (if you hate the cheaper components).
    I started off with a $500 budget, thinking that it would be an amazing bike because the bikes I had as a kid were $100. I figured 5x as much money could get me something nice. I literally had not looked at bikes in over a decade so I had a moment of sticker shock when I started shopping. I ended up with a carbon frame and full Ultegra components, about 4x as expensive as the budget that was already 5x more than what I had last ridden as a kid. Spend money on what makes you happy.
  1. Fuji 2013 Sportif 1.1c or Roubaix 1.5?
    By Phlerb in forum Bikes, Frames and Forks
    Last Post: 03-10-2013, 06:56 PM
  2. Raleigh Record Ace or Raleigh Revenio 1
    By Jaybo in forum Bikes, Frames and Forks
    Last Post: 11-20-2011, 10:25 AM
  3. Raleigh Revenio 4.0 for $1,100
    By PWDonT in forum Beginner's Corner
    Last Post: 08-15-2011, 04:38 PM
  4. Raleigh Revenio 3.0 vs. Felt F85
    By zsmyers in forum Beginner's Corner
    Last Post: 05-26-2011, 05:16 PM
  5. 2011 Raleigh Revenio 3.0
    By jcrogers21 in forum Bikes, Frames and Forks
    Last Post: 09-27-2010, 05:41 PM
Sea Otter Classic
Contest
