Results 1 to 5 of 5
    Apr 2013
    Good larger size tires
    I am riding down in Solvang Cal next month and the ride leader is suggesting bringing the largest tires that fit your bike and running a lower pressure. Was thinking about taking my gravel bike with 36 or 38. Trouble is I know what to purchase for my road bike but have no idea what a good gravel / road tire to get. Can someone help! thanks
    Probably get more response on the tires/wheels forum. And you should mention of you want light tread, knobs, smooth or what. Or just say a bit about the type of riding surface(s) you want them for.
    Jan 2016
    Panaracer Gravel King 700x38 Tubeless
    'brifter' is a lame word.
    Oddly enough Wheels and Tires just might have some info you're looking for.
    I work for some bike racers
    and a bunch of skateboards
    Reputation: Lombard's Avatar
    May 2014
    That depends on how much $$ you want to spend. It also depends on what type of terrain you will be dealing with.
    If you're flush, I can vouch for the Clement X'Plor MSO's which can handle gravel and also roll nicely on smooth pavement:
    If you're looking to go on the cheap and your off-road sections aren't much more than hardpack, the Kenda Kwests roll nice and will serve you just fine:
    -- Warren Buffett
  1. adjusting to riding a larger frame size?
    By kenken662 in forum Bikes, Frames and Forks
    Last Post: 04-14-2013, 04:09 AM
  2. motobecane messenger trade for a larger size
    By tjs317 in forum Motobecane - Mercier
    Last Post: 04-19-2009, 12:23 PM
  3. tire size for larger rider and semi-rough roads
    By cale76 in forum Wheels and Tires
    Last Post: 04-06-2007, 05:17 AM
  4. Smaller or larger frame size
    By stupidgringo in forum Bikes, Frames and Forks
    Last Post: 05-04-2006, 09:51 AM
  5. CX tire size 32 or larger?
    By DowntownBrown in forum Cyclocross
    Last Post: 04-28-2006, 11:39 AM
VISIT US AT and the ConsumerReview Network are business units of Invenda Corporation
