Results 1 to 6 of 6
    Reputation: TotalRefill's Avatar
    Jun 2011
    (my other question was already answered so) Air compressor for bike tires
    Can you use an air compressor built for shrader valved bikes/cars etc on your road bike? If you have one of those adapters would it be safe to use?
    adheres to Rule #9
    May 2009
    To answer your question "yes"
    Would I use an air compressor to pump up my road bike tires? Having an air compressor I answer this with:
    No, I use a floor pump.
    Cycling induced anoesis
    Reputation: PJ352's Avatar
    Dec 2007
    Quote Originally Posted by TotalRefill View Post
    Do you mean air compressors or tire inflators? The reason I ask is because some air compressors are rated at 100 PSI while others put out 400 PSI, so I'd advise against the latter - or anything much above 150 PSI.
    IME tire inflators like this:
    Amazon.com: Black & Decker ASI300 Air Station Inflator: Home Improvement
    suite the purpose, but use care not to overinflate because it's rated at 160 PSI.
    Jul 2011
    I use a Craftsman 5 gallon air compressor for my tires. It has an outbound pressure setting that works out well since I can just set it to 110psi and it will inflate the tires to that level.
    That being said, I am going to get a floor pump because it is easier to get a reading and fine tune the pressure since I am not sold on those adapters. Wonder if they make an air compressor attachment that will inflate a Presta valve?
    Feb 2002
    Presta w/compressor
    Quote Originally Posted by heybrady View Post
    I Wonder if they make an air compressor attachment that will inflate a Presta valve?
    You can buy a Silca head for Presta valves and then either build a "cheater" using a Schraeder valve, some pressure hose, and hose clamps or just put the Silca head on your existing compressor hose line.
    Aug 2011
    I think it should work!
  1. Replies: 0
    Last Post: 06-26-2010, 07:45 PM
  2. Best Rain Gear for Cold Rain on a hot day
    By Jank in forum General Cycling Discussion
    Last Post: 07-24-2009, 06:59 PM
  3. Rain rain, go away, Johhny wants to ride - A SHOE COVER PLEASE???
    By rugger in forum Commuting, Touring and Ride Reports
    Last Post: 07-17-2009, 05:24 PM
  4. Rain gear for 2 days of rain
    By biker in forum Commuting, Touring and Ride Reports
    Last Post: 02-21-2009, 10:00 PM
  5. Teach me about riding in the rain and rain gear
    By Bolo Grubb in forum Commuting, Touring and Ride Reports
    Last Post: 12-13-2007, 08:05 PM
