Results 1 to 16 of 16
    Jun 2013
    Problem with Flat Tires
    Hi everyone, newbie poster here with probably a dumb question.
    I bought a used Trek 7.3 about a month and a half ago in order to help rehab a knee injury and get into shape. I tore my patellar tendon last November, and the Doctor suggested biking to help with long-term rehab.
    Anyways, I rode the bike for 3 weeks or so 10-12 miles per night, 4-5 nights a week without any trouble.
    However, now for the last two weeks, I have gotten a flat tire once every other ride, all but one on the front tire.
    I have been checking the tire inside and out before putting in a new tube, and can't find anything sharp that could be causing multiple flats. I even had the LBS change/fix one, so that I could have a more experienced set of eyes look at it.
    The flats always appear to be from punctures outside the tire on the outside facing section of the tube, so they don't appear to be pinch flats, or a problem with the rim.
    So. .. .I've eliminated about everything that I have been able to research about, but I don't know what I don't know.
    One worry I have is, "what size of puncture in a tire requires a boot/patch on the tire itself?"
    Another is, "Am I too heavy?" I'm working on that. .. that's part of the reason for the bike, but I currently weigh about 265. The Trek 7.3 has 700X23 tires. Do I weigh too much? Is this a factor in these flats? Since they don't appear to be pinch flats, I hope not, but I don't know.
    Am I just unlucky?
    Jul 2011
    Pinch Flats (do a google search)
    What's your air pressure?
    'brifter' is a lame word.
    And the "wheels/tires" section of the forum, not here.
    2010 Cervelo T1 sprint bike
    Ruger 10-22TD
    Smith&Wesson M&P 15-22
    Smith&Wesson M&P 9
    oh, those belong in another forum
    Cycling induced anoesis
    Reputation: PJ352's Avatar
    Dec 2007
    As an aside, no offense meant, but at your weight I suggest going with at least 25c's, but preferably 28c's.
    Current 7.3 FX's are equipped with 32c's, so 28's shouldn't be a problem, but verify that before ordering.
    Mar 2013
    Heavier cyclists tend to impact sharp objects with greater force than lighter ones. Therefore, imagine a pricking your finger with a needle, as opposed to stabbing yourself with a needle. Also, tire quality plays a large part in flats, too.
    A chromoly steel bicycle will last just as long as titanium, if kept dry.
    Jun 2013
    Quote Originally Posted by PJ352 View Post
    Do you mean putting 28c tires on the current wheels, or will I need entirely new wheels? I'm sure that's an egregiously bad newbie question.
    Quote Originally Posted by NightTrainLayne View Post
    You should be able to run 25, 28, 32, 35, or even a bit larger on the standard wheels, so no worry about replacing the actual "wheels". Hell, you'd probably be fine w/ 23's on those wheels, they're not that wide.
    Ruger 10-22TD
    Smith&Wesson M&P 9
    Dec 2007
    He's now running 23c's. That's what made me suggest wider tires.
    OP, cx answered your question, and BTW, this is the beginner's corner, so ask whatever you like.
    Feb 2002
    You need to figure out if you're getting multiple punctures at the same point. You match the tube up with the tire and that tells you where on the tire the puncture occurred. If they are happening all over (never the same place twice) then you are either unlucky or you are not careful in avoiding debris on the road. Chances are however that the punctures are happening at the same point and that means one thing is causing repeated punctures.
    Study the puncture itself. If it is a pinhole that suggests a piece of wire (typically from car tire breakdown -steel belted radials). If it is more of a bruise in the tube that suggests perhaps a slightly damaged casing on the tire is rubbing against the tube. In any case, only when you know the cause of the flats can you figure out a solution.
    I'll be he made a typo, the FX series bikes come stock w/ 32mm tires.
    Ruger 10-22TD
    Smith&Wesson M&P 9
    Dec 2007
    Yes, I checked back and saw that the OE tires are 32's.
    Could well be a typo, but buying used one never know what (or why) sellers do what they do.
    Either way, it opened a discussion on tire size/ options/ pressures, and I know how much you love to see more threads on the latter.
    Oh man...one of my co-workers has started keeping track of how many times we have the 'pressure discussion' on weekend days at the shop. I think the record stands at 13...
    Ruger 10-22TD
    Smith&Wesson M&P 9
    Reputation: Dave Cutter's Avatar
    Sep 2012
    I started getting flats when I was 257 pounds. The guy at the LBS suggested 25C tires with thorn-proof tubes (even though I live in the mid-west... not thorn country). I also added a higher pressure rated snap-on rim tape.
    Since then I've dropped over 70 pounds and returned to using 23C tires. But I've kept the same thorn-proof tubes.
    If I didn't bicycle when the weather is bad... I wouldn't be a cyclist. I'd just be another old fat man... with a bicycle hanging in his garage.
    Urban Cycling.... Overcome your fears (a YouTube Link).
    Learn to cycle in traffic
    Or... just HTFU
    Quote Originally Posted by Dave Cutter View Post
    Damn Dave, good job on the weight loss!
    Ruger 10-22TD
    Smith&Wesson M&P 9
    When you put the tire back on align the label with the valve. It makes it easier to locate the puncture in relation to the tire.
    Take a cotton ball and run it around the inside of the tire to help locate anything protruding through the tire. This is an alternative to the time tested method of using your finger, where the protruding object is at the start of the blood trail.
    Jun 2013
    The bike definitely has 23's on it, no typo. I'll investigate getting bigger tires.
  1. %$#$ flat tires!
    By RichieB313 in forum Beginner's Corner
    Last Post: 09-05-2012, 05:48 PM
  2. flat tires
    By kleinmantra in forum General Cycling Discussion
    Last Post: 09-10-2011, 04:06 AM
  3. What would you have done? (flat tires)
    By Fixed in forum Commuting, Touring and Ride Reports
    Last Post: 03-02-2007, 10:34 AM
  4. Strange flat tire problem
    By BikeRider in forum Wheels and Tires
    Last Post: 09-21-2006, 04:55 PM
  5. The Joy of Flat Tires
    By Andy M-S in forum Commuting, Touring and Ride Reports
    Last Post: 02-03-2006, 12:46 PM
Sea Otter Classic
Contest
