Page 1 of 14 123 ... LastLast
Results 1 to 25 of 331
    gazing from the shadows
    Jan 2003
    Tips to amaze the new rider.
    The other day I went over to a friend's house to get his and his wife's bikes ready for a duathlon. I asked him if he had a workstand, and he pointed to his workbench, covered in junk. I said I meant a bike stand, but I figured he did not have one. I then said "No problem, we will just make one."
    Out comes the rope, tossed over a rafter, a slipknot went around the nose of the saddle, and viola! a workstand that made it easy to lube and tune the bikes.
    The guy was freakin' AMAZED! He looked at me like a miracle worker.
    So, and other basic tricks of the trade people would like to share? Things that you never think about twice, but that a new rider might never think of on their own?
    Bonus points if your tip includes duct tape.
    Oh, sure, take my best one....
    That's such an obvious one I'm surprised how it wows people, but I've done it on camping trips and at races and they stand and gape like I'd invented pressurized air.
    Couple of others, obvious to veterans but probably helpful to newbies:
    When fitting a chain, just stretch it around the big cog and big ring, add one link and put the sucker together. It will be close enough.
    Toe strap (which nobody has anymore, but you can use a shoelace) around the brakes to hold the pads against the rim while you adjust the cable.
    Puncture, but no patch or spare tube? You shouldn't let this happen, but if it does, cut the tube right at the hole and tie a figure 8 knot as tight as you can in each end. Insert in tire, pump up and ride (works WAY better with mountain bike tires than road rubber, but it's rideable)
    Whang the high spot of a tacoed wheel on a fence post or something to beat it more or less back into shape, then tweak the spokes with a wrench until it's rideable with the brake release open. To be honest, I've only had to do this once, but it fixed a REALLY bad wheel well enough to get us to the next rest stop.
    Anybody remember those tool-kit freewheel vises you could use to pull a freewheel so you could replace a drive-side spoke? I still have one, useless now, around the garage. A modern-day equivalent, the Cassette Cracker, is the size and weight of a church key can opener and will spin off a cassette with no other tools. On long rides I carry one, plus a couple of spokes taped to the top or seat tube. Don't know where you'll find a Cracker, though, except in my garage.
    Paranoid Android
    Reputation: Anti-gravity's Avatar
    Jul 2004
    Quote Originally Posted by dr hoo
    Some people seem to be amazed when I can:
    -Put on a tight-beaded road tire with my bare hands.
    -Adjust a disc brake so it is dead silent (no rubbing).
    -Get a stiff link out of a chain with my hands.
    -track stand
    -ride and steer my bike without hands
    -fix a slashed tire with duct tape
    Ok, I'm not trying to brag, since lots of people can do those things, but it's fun to show off sometimes .
    -R
    flinty-eyed moderator
    Reputation: Coolhand's Avatar
    Jul 2002
    Simple stuff that's good to know:
    1. New chains come with a wax paste type covering which prevents them from rusting in the box. It is not lube and forms a gritty sandpaper paste on your chain. You need to clean it off (chain degreaser does the trick) and apply proper chain lube.
    2. Proper chain lube and chain cleaning will vastly extend the usable life of your chain, cassette and rings. Old T-shirts are great for general drivetrain cleaning.
    3. If you are road riding, you need to carry: at least one spare tube (protected from punctures in your saddlebag), at least two tire levers, a basic multi tool, a method of inflating your tires (pump or CO2 cartridge and inflator), tire patch kit or glueless patches (for double flats ect.) and at least $5 cash. That is the basics, you can carry more stuff but less then that and you will be walking home someday in uncomfortable shoes.
    Dr. Cox: Lady, people aren't chocolates. Do you know what they are mostly? Bastards. Bastard-coated bastards with bastard fillings. But I don't find them half as annoying as I find naive bubble-headed optimists who walk around vomiting sunshine.
    ..a trick of the light..
    Reputation: Tim M's Avatar
    Apr 2005
    With a cut tire, where the tube will stick out and pop again, place a dollar bill (or 5 pound note...) inside and insert/inflate new tube. Done this several times and I always carry a bill with spare tubes.
    ..and too much caffeine, he thought.
    Shirtcocker
    Reputation: Bocephus Jones II's Avatar
    Oct 2004
    Quote Originally Posted by Tim M
    energy bar wrappers also work for this.
    "I regard the brain as a computer which will stop working when its components fail. There is no heaven or afterlife for broken down computers; that is a fairy story for people afraid of the dark." -S. Hawking
    OES
    OES is offline
    Jan 2002
    When you come to an obstacle in the road, push down, pull up, hop over. The first time you manage it -- well, talk about an amazed newbie.
    I don't exist
    Reputation: HAL9000's Avatar
    May 2002
    Cut up FedEx, UPS, DHL envelope (Tyvek)strips are better & ~~free & you still have the $5 bill to spend on a congradulatory beer for your field expediency.
    Rocket Sturgeon
    -2B1 Ask 1-
    Fast Stinky Fish
    in KY jelly
    Apr 2005
    When using any hand held pump, find a stone or a fence post and rest the end of the pump on it; effectively converting your hand pump into a mini track pump.
    I also second the no lever approach to taking tyres on and off.
    Cold day that's gonna warm up? few sheets of newspaper up the jersey, take out when warm.
    Putting wheels in? Front first; it's the easiest and lifts the front of the bike making the rear easier, and always remove the wheel in the smallest sprocket, that way you know where it goes when replacing.
    Arm warmers are the greatest bit of kit.
    Shaving legs? always shave towards the knee, ie down at the top, up from the feet.
    Good trick? picking up a dropped cap while riding along.
    Best bottle cages? Metal 'cos you can bend them in to grip the bottles for cobbles and rougher races.
    Rainy day? cotton cap under helmet = dryer eyes.
    Power Bars take more energy to chew than you get from the bar itself. ;)
    Spicy Dumpling
    Reputation: VaughnA's Avatar
    Jun 2003
    Quote Originally Posted by HAL9000
    I use tyvec CD/DVD holders as a bag for my tubes in my seatpack. It protects the tube from my toolkit and other stuff in the bag, and can be used to boot a tire like you said.
    Gone for a bike ride ....
    Reputation: harvey's Avatar
    Feb 2005
    Quote Originally Posted by olr1
    DEFINITELY don't store your Power Bar away from body heat when it's cold. They could break your teeth! Clif Bars are another story .... much softer and tastier.
    ---- Perfection is our goal, but excellence is tolerated. ----
    scruffy nerf herder
    Reputation: funknuggets's Avatar
    My tips....
    Im sure the arguements will come, but after many years and threads read, this is my price for performance tips. All of these answers have their caveats, but these ARE the correct answers for the newbies.
    1. The best upgrade for your money: If your frame fits you CORRECTLY: Wheels, wheels, wheels otherwise FRAME FRAME FRAME
    2. The best frame material for your money: Aluminum
    3. Ultegra vs 105s, for the money: 105s
    4. Carbon handlebars, Cranks, or handlebars: For the money, Handlebars
    5. Shimano vs Campy: again price for performance: Shimano
    6. the best sports drink....: price for performance.... Water with a touch of salt
    so sayeth the funk....
    Chris
    "The RBR Lounge. You won't ever find a more wretched hive of scum and villany. We must be cautious."
    Squirrel Hunter
    Feb 2003
    My Tip
    Quote Originally Posted by funknuggets
    Im sure the arguements will come...but these ARE the correct answers for the newbies...
    Don't believe everything you read on the internet.
    Just Riding Along
    Reputation: KeeponTrekkin's Avatar
    Aug 2002
    32 spoke wheels...
    are the best long term value. Low spoke count wheels may look cool but can also leave you walking home or waiting for a factory rebuild.
    Bikes are like bottles of beer; as soon as you get one, you want another.....
    Cycling
    Reputation: cycling's Avatar
    Jul 2004
    i third the no tool/tire off method
    and to learn that it takes...well.........practice
    i cant repair a flat within 2 minutess now w/no tools(Execpt patches_
    Shirtcocker
    Oct 2004
    Quote Originally Posted by cycling
    certain combos are a real pain though. carry your tire irons just in case or you may end up with blisters on your thumbs.
    scruffy nerf herder
    oh yeah?
    Shimano is better than campy!
    honestly (I agree).
    Chris
    Squirrel Hunter
    Feb 2003
    Yeah!
    Interesting, not even the one I was warning newbies about. Sounds like someone may have a predisposed bias.
    ...this is my price for performance tips...
    After you have a properly fitting and fitted bicycle the best upgrades are changing stock components that do not fit your body or riding style. Saddle, tires, cassette, shoe & pedal combination, computer with cadence... Buy a couple of pairs of good shorts.
    Although for a newbie comfort often times trumps performance and they may develop their riding ability quicker on a bike that they can put long miles on rather than an aluminum rocket that lets them go fast over shorter distances.
    Hmmmm, is this still true in the longer term with Shimano's transition of its product lines to 10 speed? Certainly something to think about depending on the short and long term goals of the newbie.
    Well handlebars over cranks but properly sized handlebars should have been dealt with in the bike fit and carbon is really not necessary although it may look cool. Why would you be putting carbon handlebars and cranks on a 105 level bike?
    Maybe or maybe not. A lot of factors to look at and the old rule of thumb from 2 or 3 years ago may have changed with recent developments in the market. Certainly a point to be researched and discussed in a different forum.
    Print this list so you can put it in your pocket and read it while you try to gather enough energy after bonking to make it back home.
    Paranoid Android
    Jul 2004
    Utterly Infallible!
    LMAO
    -R
    AIE
    AIE is offline
    midnight melon mounter
    Reputation: AIE's Avatar
    re: bike stand
    Same can be accomplished by perching the nose of your saddle on a low-hanging, horizontal tree branch. Bikes balance quite well this way.
    too fixed, too furious
    Feb 2005
    "Well handlebars over cranks but properly sized handlebars should have been dealt with in the bike fit and carbon is really not necessary although it may look cool. Why would you be putting carbon handlebars and cranks on a 105 level bike?"
    cause they dropped almost a half pound off the bike, and were not much more than upgrading to an ultegra crank and bb.
    Reputation: sgt_hedgehog's Avatar
    Jun 2004
    especially for 2006!
    10 SPEEEED!!!!
    Bike Dude
    Sep 2003
    Yet another bike stand
    Using motorcycle tie down straps with the s-hooks. Hook one end to a cross beam and the other end around the seatpost, the other strap will hand from another cross beam (or hook) and then around the stem.
    Reputation: RodeRash's Avatar
    May 2005
    Quote Originally Posted by VaughnA
    Old cotton sock for the tube. Holes in it are OK, also the ones that show up in the laundry with no mate. Put the tube in the foot end and fold the top over. Then store the CO2 cartridge, irons, etc. in the "leg end." This does a couple things: Keeps the tube from getting chafed in the bag against the tools, but also keeps the tools from chafing your seat bag against the rails on the saddle. Finally, when you do have a flat or a minor roadside repair, you have a "grease rag" to clean up your hands.
    NEVER pass up a chance to top off your water bottles!
    Sodium bi-carb in the bottle with water is an electrolyte and better than salt because it will settle your stomach a bit on a hard ride. A pinch will do ya!
    Leather pouch coin purse for keys and change. Keeps keys/change from poking a hole in your $100 jersey, and keeps the contents together.
    Speakin' of jerseys. Zippers cost money. When looking at jerseys and comparing prices, get the one with the LONG zipper that comes all the way down to your navel. Hang the cost! It will pay for itself in the long haul. Also, put it on. Zip up the neck. It's nice if you can un-zip the neck with one hand and no fancy finger work. That's a function of fit and design. Helps too if the zipper tab is a decent size.
    For the tourist types -- DON'T secure clothing on the bars. You haven't lived until that shirt comes untied and wraps around the front wheel!
    Apr 2005
    Shoes? $100 plus....
    Socks? $1.....
    Put socks over your shoes when it rains.
  1. Changing shift cables - tips, tricks?
    By innergel in forum Components, Wrenching
    Last Post: 10-27-2012, 03:44 PM
  2. Avoiding a Skull Fracture - tips?
    By litespeedchick in forum General Cycling Discussion
    Last Post: 12-26-2011, 01:03 PM
  3. 3% Advantage by someone drafting U
    By 6was9 in forum General Cycling Discussion
    Last Post: 07-23-2010, 08:05 PM
  4. 1 Kilometer at the 2008 Olympics....
    By Fickle in forum Racing, Training, Nutrition, Triathlons
    Last Post: 10-05-2004, 04:04 PM
  5. Decent starter bike- Specialized Dolce? (5'2" rider)
    By Nuget in forum Bikes, Frames and Forks
    Last Post: 05-23-2004, 06:58 PM
