Results 1 to 25 of 28
    Jul 2017
    Upgrading specialized allez claris to tiagra and fulcrum racing 5
    Hi, I'm looking for a roadbike,
    Narrow down to the new Specialized allez 2018,
    1) allez elite 105 $1200
    https://www.specialized.com/us/en/me...ezelite/133817
    2) allez claris, $750
    https://www.specialized.com/us/en/me...e/allez/129052
    Looking for opinions, it is ok if i bought the claris one and upgraded to tiagra and fulcrum racing 5, conti tyres
    or just take the 105 one and upgrade conti tyres?
    Your opinion is much appreciated.
    Sent from my X9006 using Tapatalk
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    You will spend more than $450 buying the parts, NVM the labor. Buying the bike you want up front saves money later.
    Jul 2017
    Kinda agree
    but the 105 above don't have full groupset, Crankset ia praxis and tekro caliper brek.
    Jan 2005
    Quote Originally Posted by padangchangkat View Post
    Kinda agree
    Yea, that is a common tactic to increase profit margin by using sort-of-equivalent-parts. The crank you probably won't notice, and either way you at least get a threaded BB. The brakes, put KoolStop pads/shoes and they should perform fine.
    Jul 2017
    Ohh ok bro thanks is a nice idea, newbie for rb so have to ask and Google around for info,. Thanks
    Feb 2002
    Per the others, buy the best bike you can afford. And then ride it, wear out the tires, and buy the tires you want. No need to swap out brand new tires.
    Reputation: Lombard's Avatar
    May 2014
    Kinda agree
    but the 105 above don't have full groupset, Crankset ia praxis and tekro caliper brakes.
    This is true. However, the 105 bike has much better wheels - DT460 vs. the entry level Axis wheels on the Claris bike.
    Nothing wrong with the Praxis crankset - much better than the junky FSA cranksets many new bikes come with. Nothing wrong with the Textro brakes either.
    This one is a no-brainer - get the 105 bike!
    Jul 2017
    Oh, just thinking swap with lighter tyres might improve the feel n ride
    Jul 2017
    Ohh that obvious yeah, this is my first time buying rb, so quite careful in spending and investing on the bike.
    May 2014
    FYI, last winter, I built a set of wheels for myself using those same DT Swiss R460 rims with Dura-Ace hubs. Those are nice rims. The tires are heavy wire bead tires, but tires wear out and can easily be replaced. You don't buy a bike for its tires.
    Jul 2017
    Nice, so it's seem the 105 is quite a good spec.
    And do r460 come with sleeve join?
    May 2014
    Yes, R460s are sleeved - a non-issue. When they were new, I could hear a faint cyclical noise when the brake pad went past the joint. 100 miles worth of braking smoothed that all out.
    Jul 2017
    Well that a good Updates, thanks. waiting for above model to arrive, going for test ride. First rb will going to try aluminium frame, like specialized allez.
    Apr 2012
    I just went thru something similar. I have a 14 Allez w/claris and I was going to upgrade, after talking to a cpl of lbs' about this I am now the owner of a brand new Roubaix SL4!
    Jul 2017
    Quote Originally Posted by stogies4life View Post
    Wow nice, quite similar experience, thanks.
    Jan 2008
    I did that with a specialized frame, worked out great. two things.
    the "elite" designation historically applies to two different classes of frames, you want to make sure that you get an "E-5." E5 is historically among specialized's best aluminum frames, modeled largely on the carbon tarmac footprint. they are solidly built and fast as hell, if you get one under a thousand with lowbrow components, jump on it.
    two, you can always upgrade components one at a time, jenson is a good place to find discounts. the easiest upgrade, depending on where you shop, is usually the wheels. from there the drivetrain, including crank, chain, shifters, and derailleurs. just remember, the crank and chain wear at the same rate; sometimes you can get away with changing just the chain, but if the crank has significant wear on it, it all has to go.
    I learned that one the hard way when my crank started to skip; changed the chain, no go. tried new ring, no go. eventually upgraded crank and chain had me up and cruising again.
    in short, though, the reson I recognized this was I upgraded an e5 from 105 to ultegra and Easton wheelset. couple years ago, I think. first got the shifters for about a buck thirty, crank about a hundred and a chain about thirty. 250 I think for Easton 70's. and it was like a new bike. aluminum will wear and start to bend over time; still plenty stiff and built like a brick shythouse. worth the time and money, do your homework....
    May 2014
    Quote Originally Posted by easyridernyc View Post
    ......the crank and chain wear at the same rate..........
    I really hope you meant the chain and cassette wear at the same rate. I have never heard of a crankset that wears as fast as the chain. It should last for at least 2 or 3 chains. I can't imagine that you weren't skipping on your cassette long before.
    Jul 2017
    Yea bro nice sharing, the bike link above do come with specialized e5 premium frame, and yes planning to upgrade especially tyres and wheelset. Seem fews rider said claris is ok, might ride with claris before upgrading. My first roadbike.
    Jan 2008
    lol...yeah, chain and cassette. crank, or crank rings not nearly as fast
    Jan 2008
    shimano components are compatible, that's the other thing you can mix, you don't have to upgrade everything at the same time. that's a good deal for that bike, the components aren't much, but the frame is very nice. grab it, get some pedals and shoes. learn how to shift, go up hills, go fast on straights, see how you like it, then think about the upgrades. the frames were prettier then, Columbus tubing. I still have this bike and it still flies like the WIND man....
    http://1mg.me/image2.aspx?filename=2...e.jpg&f=Photos
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    Would recommend the 105 here as well. You'll get something closer to Shimano's most up-to-date design such as 11-speed, hidden cable routing, etc.
    Jul 2017
    Oh i see, will consider bro. But both the bike come with hidden cable routing.
    Neophyte
    Jul 2007
    Sorry didn't realize how out of touch I was with Claris/Tiagra current generation Shifters
    Feb 2014
    Man do the 105. 105 is a friggin workhorse! Unless $450 will put you in the poor house do the 105. All around better deal. Getting it on a new bike is the way to go. Cheaper and ready to roll from the get go. Get the best you can afford. The better the bike the better the chances that you will really use it. Spend it if you got it! Can't take it with you.
    Have you checked out any other brands? I just bought a Trek Domane SLR6 and love the bike! The comfort of this bike is amazing. They have an aluminum version in the same price range. Ride em all! Part of the fun of getting a new bike. LOL! My 2 cents worth
    Good luck.
    Bill
    Jan 2008
    Quote Originally Posted by fishboy316 View Post
    Good luck.
    Bill
    you can get 11 speed 105 shifters for a lot less than 450. you can get the whole fcukin group for 400 bucks, complete. 200 for the shifters alone, depends on your budget. I think the group is worth it, put the Claris stuff on e bay, you'll get a couple hundred back, use that towards your wheelset pbk has them on sale now for 215, plus pbk always has a fifteen percent code and usually free shipping, if those are the wheels you want. if you want the link for the shifters or the group message me i'll send it through nw
  1. Recommendation between Salsa Vaya Claris or Specialized Sequoia Base?
    By mphilleo in forum General Cycling Discussion
    Last Post: 03-23-2017, 03:01 AM
  2. Upgrading crankset - shimano claris compatability
    By tomz01 in forum Components, Wrenching
    Last Post: 01-17-2016, 08:06 AM
  3. How to upgrade Claris to Tiagra, etc...
    By deapee in forum Trek
    Last Post: 05-10-2014, 07:44 AM
  4. Replies: 2
    Last Post: 08-07-2010, 10:30 PM
  5. Fulcrum Racing 1 vs. Fulcrum Racing 3
    By uscsig51 in forum Wheels and Tires
    Last Post: 07-19-2006, 12:09 PM
