Results 1 to 11 of 11
    Jul 2011
    What's wrong with belt drives?
    Say you have a road bike that was made to accommodate a multiple-gear internal hub, and it uses a belt instead of a chain.
    - tougher to get parts in a store
    - first gen belts will clog in snow
    What other problems are there with belts? Why are more people not using them if they're supposedly lower maintenance, lower friction, lower weight?
    Aug 2012
    Weight for the total combination would be higher I would guess, but belts have been used on motorcycles for years reliably. On a fixed gear bike it could work easily, still probably a weight increase though.
    Trek Domane 5.2
    Cannondale Synapse 3 Ultegra Disc
    Fuji Cross Comp
    Trek Dual Sport 8.4 (sold)
    1969 Camaro Pace car - numbers matching frame off resto
    1969 Camaro Coupe
    Reputation: Dave Cutter's Avatar
    Sep 2012
    Quote Originally Posted by jfd986 View Post
    .... What other problems are there with belts? Why are more people not using them if they're supposedly lower maintenance, lower friction, lower weight?
    I have wondered about this myself. Couldn't the bottom bracket be replaced with a non free-wheeling 3 speed hub, and the rear hub replaced with a normal 8 speed hub? Making a cog-less 24 speed.
    But then.... why use a belt when a direct drive [shaft] could be used (Shaft drive bicycle | Flickr - Photo Sharing!). Hasn't all this... already been tried.
    Feb 2002
    Weight and efficiency
    Geared hubs are very heavy, very expensive, and very inefficient. Other than that it's a great idea. And people have been trying to get shaft drive to work for about 100 years. Technically possible but all the same problems of internally geared hubs. In motorcycles where you have power to spare people don't mind so much. When YOU have to supply all the power people are going to reject something that might be 90% (or less) efficient compared to the 98% efficiency of chain drive.
    Sep 2009
    I am definitely considering a belt drive on a NuVinci N360 hub for a commuter bike. The hub is about $400, so not particularly expensive, though they are heavy. My wife has one on her Breezer and loves it.
    Jul 2011
    I think I'd hate the efficiency drop too much. lubing and cleaning the drivetrain takes me 5-10 minutes, and I can get faster at it. Would rather do that than push harder for less.
    wim
    wim is offline
    Feb 2005
    I think I'd hate the efficiency drop too much. .
    Well, it's not that bad. Most geared hubs are close to 98% efficient in the middle gear. Their efficiency drops incrementally as you go towards the lowest and the highest gear to about 90% at the extreme ends of the gear range.
    /w
    Sep 2007
    Belt drive? too quiet. You will soon be forced to ride with playing cards clipped onto your stays so your bike makes more noise. (it's a safety feature!)
    Reputation: nhluhr's Avatar
    Sep 2010
    Quote Originally Posted by wim View Post
    /w
    That's a pretty big damn drop. People pay extremely large amounts of money to gain smaller fractions than that.
    Swapping wheels and fixing flat tires sucks royally with internal hubs as compared to a derailleur set up. That makes them a pretty bad idea for most road cyclists. I'd also much rather just buy a different cassette over an entire, expensive, wheel when if I want to get different gears.
    wim
    wim is offline
    Feb 2005
    Quote Originally Posted by nhluhr View Post
    They do, but those are people who wouldn't be caught dead riding a bicycle with a geared hub for reasons that have nothing to do with mechanical efficiency.
Sea Otter Classic
Contest
