Results 1 to 2 of 2
    Feb 2005
    Question 10 speed capatibility w/2003 Giant TCR 1 Composite
    Does anyone know if the new 10 Speed Ultegra is compatible with my 2003 Giant TCR 1 Composite frame. I'm thinking about purchasing a bike online with the 10 speed groupo on a different frame and then swapping the components.
    Thanks
    a frame is a frame...
    Newer road bike frames are pretty much the same. There are several possible minor problems. There may be a difference in the front derailleur mounting. There are braze-on types and three different clamp-on diameters.
    There are also two bottom bracket standards still in use. Most Italian frames are still using Italian threads (36mm x 24tpi), while the vast majority use English threaded BBs.
    Another possible difference is the headset. There are several integrated types and the conventional threadless type in use.
  1. 8 speed Ultegra died; want to go to 10 speed
    By dimitry in forum Components, Wrenching
    Last Post: 04-14-2005, 11:58 AM
  2. what if i want 8sp?
    By colker1 in forum Components, Wrenching
    Last Post: 06-05-2004, 04:22 PM
Sea Otter Classic
Contest
