Results 1 to 8 of 8
    Oct 2003
    1999 Voodoo Rada Question
    I am 6'2" and have an opportunity to pick up a 60cm rada frameset. I think the TT length is 60cm as well. I believe it may be a bit long but was looking for some help? I ride a 58cm Cannondale R1000 at the moment and fits well with a 120mm stem. Any help would be appreciated.
    Mar 2009
    i would think that size would do you well with a shorter stem.
    Oct 2003
    Thanks Bro. I've decided to get it.
    Feb 2002
    My late 90s candy green Voodoo Rada 853 frame is 60 cm size,non- compact, with a 59cm T-T c-c.
    Oct 2003
    Fork Choice
    Quote Originally Posted by jordan
    Thanks. Can you recommend a fork with appropriate rake?
    Feb 2002
    Quote Originally Posted by brihombre
    My 60 cm Rada 853 classic geometry frame did not come with a original fork from Supergo,but I have been using a 43 rake carbon Kestrel fork .The handling is fine w/ the 43 rake.I think it has a 74 deg. HT angle so I would avoid 45 rake forks.The original fork was a one inch threadless Ritchey carbon.
    Reputation: Zombie Sintesi's Avatar
    Apr 2009
    Voodoo Rada. Who is Voodoo Rada?
    Feb 2002
    Quote Originally Posted by Zombie Sintesi
    Ask a Zombie....
