Results 1 to 10 of 10
    Jul 2007
    2005 Cervelo R2.5: What tubes got separated from joints ?
    Hi,
    In the 2005 Cervelo R2.5 - b e s i d e s the down-tube problem on which there was the recall in late 2006 anybody knows what other tubes got loosen from joints ? (i.e. chain stay tube, seat tube, etc..)
    If anybody has photographs of such separations of tubes from joints - that would be appreciated.
    Thanks
    Jeff
    key
    key is offline
    Mar 2004
    I had an 05 R2.5 and the drive side seat stay tube came unbonded, at the wheel clamp. Cervelo did replace the frame, no questions or hassle.
    cheers
    Apr 2003
    Jul 2007
    Thanks.
    Mar 2006
    Drive side chain stay
    The right side chainstay unbonded at the wheel on mine after almost three years...Replaced under warranty with an R3 within two weeks.
    Jul 2007
    Thank you JustinTur
    Juanmoretime
    Reputation: Juanmoretime's Avatar
    Nov 2001
    A fellow RBR member, search Flying, had the two piece bottom bracket sleeve come unbonded twice. Two different frames. He now rides a Look 585.
    For my next trick I will now set myself on fire!
    Jul 2007
    Can you pls explain
    hi - could you please explain - search the term 'flying' ? ? not sure I und'd you - thanks.
    Juanmoretime
    Nov 2001
    Quote Originally Posted by jeff3069
    Sure. Flying is a RBR forum member's screen name.
    Jul 2007
    Flying screen
    If you could give me the link to this Flying screen, that would be appreciated (sorry I am not familair with that..)
