Results 1 to 3 of 3
    dot
    dot is offline
    badass
    Reputation: dot's Avatar
    Mar 2004
    Is 575mm ETT too long for 179cm height?
    I made a discovery that my 56cm frame (a bit sloped) actually has ETT of 575mm. I wonder if it's a bit long for me. I run it with a 100mm stem and feel quite fine. When I first sat on the bike in the shop, it felt just right like my XC hardtail and I bought it without thinking how long it is.
    I'm curious what ETT and what stem is "normal" or recommended for 178-181cm/5'10"-5'11".
    Feb 2003
    I'm 5'11" and all my road bikes have a 57cm ETT and I use a 110mm stem. Don't know if it is "normal", but this works for me. Your setup would be 5mm shorter if you are only considering ETT and Stem length.
    Reputation: civdic's Avatar
    May 2009
    I'm 5' 11" and I ride a 56 and run a 120mm stem. Depends on your proportions. Were you fitted for the frame?
Sea Otter Classic
Contest
