Results 1 to 3 of 3
    Oct 2013
    Asymetric Frames
    I has been discussed in other threads that if the bike has asymmetric frames, the rear triangle measures different on each side of the rear wheel.
    I was under the impression that most asymmetric frames vary the vertical dimensions of the chain stays and don't mess too much with the horizontal width.
    Am I all wet?
    BANNED
    Dec 2006
    Regardless of the path the seatstays or chainstays take, the rear wheel HAS to be aligned with the center plane of the frame.
    The position of the dropouts MUST be equidistant from the centerline of the frame, and track in the same plane as the front wheel. There's no avoiding the rule.
    Oct 2013
    We are not discussing alignment, we are discussing the distance from the chainstays to the rear wheel rim being equal on both sides. That has nothing to do with the alignment of the dropouts.
    On your issue, as long as the front and rear wheel axles are in alignment, the frame could be complete abstract plastic and the bike would handle.
    BANNED
  1. Replies: 30
    Last Post: 07-14-2017, 02:41 PM
  2. Dedacciai Frames Now at Pro Bike Supply! 15% off all frames!!!
    By ProBikeSupply_Kyle in forum Hot Deals
    Last Post: 04-04-2013, 04:31 AM
  3. Old Hotness: Carbon Frames. New Hotness: Buckypaper Frames?
    By bobski in forum General Cycling Discussion
    Last Post: 10-22-2008, 11:47 AM
  4. Questions: "lively" frames; good "planing" frames...
    By elvisvelo in forum Bikes, Frames and Forks
    Last Post: 10-16-2008, 06:06 PM
  5. CAAD frames V System six frames
    By ralph1 in forum Cannondale
    Last Post: 08-08-2008, 01:46 PM
