Results 1 to 25 of 30
    Aug 2017
    Bottom Bracket help
    I'm completely lost here, hopefully someone can help.
    Building a Chinese carbon frame for a friend, and I can't find a bottom bracket that will work. It currently has a BB30, which the OD is correct, but it wont accommodate the 24mm shimano crank shaft. I ordered a set of BB30 adapters and they make the total width too wide for to have enough crank shaft exposed to mount the left crank arm. The shell is 90mm with the plastic cups in place.
    Aside from using a SRAM crankset, what are my options? He's already bought a 6800 groupset.
    'brifter' is a lame word.
    90mm is exactly how wide it should be. A normal english threaded frame is 68mm, the cups are 11mm each. 90mm. A Trek carbon road bike is...BB90...90mm. If your friends bike is 90mm w/ the adapters installed and you can't get the left arm on you're doing something wrong. I can't say what w/o seeing the bike.
    I work for some bike racers
    and a bunch of skateboards
    Aug 2017
    Its 90mm before the adapter are installed. Sorry if I wasn't clear.
    Forever a Student
    Mar 2014
    Quote Originally Posted by Wattup View Post
    Still not clear.
    I'm going to throw out a guess here:
    Grab a rubber deadblow mallet.
    Hit the driveside crank arm/spider firm.
    Presto.
    Now you have enough room to install the left arm.
    Sometimes it takes a man's touch.
    use a torque wrench
    Jan 2010
    it's not BB30 then, is it.
    BB30 = 42 mm x 68 mm.
    If you don't know what you have, how can we help?
    Suggest you try again with the description.
    There's sometimes a buggy.
    One.
    It's definitely not BB30...
    Chinese carbon you say?
    Jun 2015
    Are you sure it's not BB86 or BB386Evo? It's not BB30 if the shell is remotely close to 90mm wide.
    Oct 2002
    a couple of pictures will help but if you can insert the long spindle into the BB from both sides of the adapter to check bearing clearances try the rubber mallet taps on the drive side crank to drive it through the non drive side bearing. If in the check you can't insert the spindle through the non drive side bearing you may have a SRAM GXP BB adapter which has 24mm bearings on the right and 22mm on the non-drive side. Pics please.
    Jul 2016
    Quote Originally Posted by ceugene View Post
    Yeah, my guess would be BB86 as well. Quite common on Chinese frames.
    Sent from my Pixel using Tapatalk
    Reputation: Lombard's Avatar
    May 2014
    Does he have an organ donor card?
    Aug 2017
    Quote Originally Posted by aske View Post
    Thanks, I'll give that a try.
    Aug 2017
    Quote Originally Posted by bikerjulio View Post
    I'm asking the question because I don't know what size it is. I used a micrometer to find the measurements, which I've included in my original post, in an attempt to find a solution. I don't have any experience with these Chinese frames.
    Aug 2017
    Still not clear.
    Presto.
    You could beat on this thing all day long and it's not going to budge unless you smash the carbon. The right side crank arm and chainrings are snug against the frame and I still don't have enough spindle on the other side to mount the left crank arm with the adapters in place.
    Jan 2010
    Sorry but you continue to make no sense at all. Your original post said it was BB30. (should be 68 mm wide) with no measurements. Here it is again
    Later you said it was 90 mm wide without cups in place.
    One does not need a micrometer to tell the difference.
    You have not posted the diameter either.
    Just saying "chinese carbon" is also fairly meaningless.
    Why not just post the width and diameter of the BB shell? Are bearings installed?
    A picture would also help.
    One.
    Aug 2017
    I didn't say I needed a mic to tell the difference. Yes, he installed BB30's (which is why I said it has BB30), which have an OD of 42mm. Being as you seem to be a self-proclaimed bike guru, I thought you would have this information. The only reason I even mentioned that it was Chinese is because it's not like I can go to a manufacturers website or customer service for help. If this doesn't make sense to you, how about to refrain from commenting? Ever consider that approach, opposed to being a smartass?
    The shell is 90mm. Diameter is 42mm. Crank spindle is 24mm. What can I put in there that will work? That's all I'm asking.
    Jan 2010
    Just a student of BB standards trying to help.
    I'm not aware of any standard that meets what you say you have there. BB386EVO is closest but that would have the BB30 bearings in cups pressed into a 46 mm dia shell. The adapters for Shimano look like this for that 386EVO Adapter for 24mm Spindle Cranks (Shimano, FSA, etc.)
    One.
    Oct 2002
    OP, post some pics of your measurements and the BB area please. Do you have a camera? Honestly a picture is worth a thousand words and this thread is already way too confusing. You asked for help, we tried to but from the get go your description was confusing. What make is the make and model of the frame and adapter?
    Apr 2012
    I assume the problem is attempting to use a BB386EVO adapter intended for 86 mm shell on this press-in bearing 90 mm shell. I have no experience, but just looking at things it seems like the adapters will add a couple mm width on each side.
    scott s.
    HTFU. You've half-asked so many questions it's no wonder none of us can help you. If the frame's bb shell is indeed 90mm wide w/ a 42mm hole in it you're not going to be able to install a Shimano 24mm axle crank...as far as I know. And I know a lot about bikes.
    Jul 2013
    Cannondale should be f'n boycotted until they go bankrupt for all of the trouble they caused by sparking these new BB standards - absolutely none of which have been shown to offer any benefit whatsoever over the tried and true English threaded BB that has served us flawlessly for decades.
    Oct 2002
    I've never bought a Cannondale, bought plenty of US made bikes but.
    Jan 2010
    Quote Originally Posted by scott967 View Post
    scott s.
    don't think so.
    BB90 is 90.5 mm wide with 37 mm moulded in bearing seats, taking a 37 mm od x 24 mm id bearing. Trek standard designed specifically for Shimano cranks.
    OP has insisted that it's 90 mm wide with BB30 size bearings, and we have pointed out that there's no such thing. Assuming he's correct about bearings the closest would be 86.5 mm wide BB386evo. Hence my advice.
    One.
    Jan 2010
    BB86 is designed for Shimano and would not require adapters. So why would OP have a problem?
    One.
    Jul 2016
    I'm just guessing wildly. Would be nice with some pictures...
    Apr 2014
    Quote Originally Posted by Waspinator View Post
    What does Cannondale have anything to do with any of this?? Do you know how many different headset standards there are? People always want lighter, stiffer, faster bikes & the manufacturers complied. You cant't offer the public those things without breaking some eggs.
    Bigger bottom bracket shells = greater stiffness & allows larger tube shapes for aerodynamics. The same thing happened with the headtube area. All this stuff was going to happen regardless. But I do understand your intent if somewhat misguided.
  1. Help needed - can't get crank off bottom bracket
    By CRM in forum Components, Wrenching
    Last Post: 12-14-2004, 10:47 AM
  2. Bottom Bracket situation, Please Help
    By Coppi1952 in forum Components, Wrenching
    Last Post: 10-06-2004, 09:47 AM
  3. Bottom Bracket Help
    By paramountz in forum Components, Wrenching
    Last Post: 07-12-2004, 05:01 PM
  4. Help with stuck bottom bracket
    By mfuchs in forum General Cycling Discussion
    Last Post: 05-19-2004, 04:30 PM
  5. Bottom Bracket Help
    By morkm in forum Components, Wrenching
    Last Post: 02-29-2004, 04:43 PM
