Results 1 to 15 of 15
    Mar 2018
    Lightbulb Cannondale CAAD12
    Hello everyone,
    I was thinking about getting a new 'stock' CAAD12 with ultegra.
    Some people have mentioned that they have problems with the FSA BB30 Bearings that are provided - causing creak sounds that simply do not go away after proper maintenance. Ending up spending lots of money on part replacement.
    My question: Is it a manufacture fail of Cannondale Hollowgram SI crank combined with FSA bb30 technology that causing this issue?
    Would it be possible to replace the stock cannon crank/ FSA BB with a simple threaded BB instead? Would that frame 'fit' the threaded BB? (ofourse changing the crank too i guess)
    Thank you,
    With regards
    'brifter' is a lame word.
    It's not a bearing maintenance issue, it's a BB30 design issue. Pressing a steel bearing into an aluminum frame will cause noises at some point. There are press-in threaded adapters that allow threaded bottom brackets in BB30 frames. They are installed w/ a sleeve-retaining loctite.
    FSA BB30 Threaded Adapter (B3119) | Chain Reaction Cycles
    Since you don't own it yet I'd just buy a different bike.
    I work for some bike racers
    and a bunch of skateboards
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    Quote Originally Posted by Bariuum View Post
    First off, BB30 technology is by Cannondale. They invented and patented it.
    There are two issues with the design:
    1) steel bearings in an aluminum race. Any movement causes creaking.
    2) using a crank that doesn't have good side loading to secure the bearings from movement. (Shimano cranks have very little side loading and notoriously creak the worst in a BB30 setup.
    IMO a BB30 (or PF30) in a carbon frame with a Hollogram crank is a pretty sweet design. BB30 in anything else is a crap shoot.
    Yes. There are several brands of BB30 adapters and they work great. Only caveat is you need a crank with a 24mm spindle.
    https://fairwheelbikes.com/kcnc-bb30...ttom-brackets/
    Mar 2006
    I have a 2015 CAAD10 that I purchased in Feb 2015. It has the Hollowgram Si crank on it. This bike has seen many races and I just had to have the bearings replaced for the first time January 2018. That is with lots of races over the past three years. As for creaking, it never creaked until after I had the bearings replaced and even then it's only done it less than a handful of times. Funny thing is, it never creaked even once before the BB was overhauled. I'm not sure about the material thing because my Super Six Evo Hi Mod will occasionally creak when I'm out of the saddle climbing really steep climbs. Heck, even Phil Gaimon's Youtube video, of him climbing Pikes Peak, you can hear his bottom bracket creaking on his Evo too.
    Mar 2018
    I feel very comfortable with the CAAD frames, plus they offer a good value deal for that price. You get a strong alu frame that you're not afraid to scratch with wheels and ultegra set. What else is possible to get for that price which is going to be durable? Buying a used carbon bike is a risk, since you don't know how the frame was handled. That's just my view.
    https://www.bike24.de/1.php?menu=100...product=242066
    One thing I have trouble understanding:
    There is a suggestion to use this rotor to convert a 30BB to a 24BB that will fit shimano crank. The Caad 2016 models had a machined ridge inside. I have no idea about this frame if it will work on it.
    Combining this rotor with a 24mm crank that I will have to order separately - in overall big picture - will it force to make any other additional changes to the groupset that comes together with the bike?
    Rotor BB30 to 24mm Steel Road Bottom Bracket | Chain Reaction Cycles
    Is it a risk to take to fit that new crank? Or I should just avoid getting a CAAD bike?
    Thank you
    Mar 2018
    Thank you
    Mar 2006
    That's interesting. The only 2016 CAAD with standard BB30 was the CAAD 8 105. The CAAD12 had BB30A and the two aren't interchangeable.
    Quit upgrading & ride!
    Reputation: Cat 3 boy's Avatar
    Aug 2002
    I've been riding a CAAD 12 as my winter bike, with a Wishbone BB30a insert to allow me to use my Campagnolo Chorus chainset, it fitted easily, it doesn't creak, the bike is great, 7.3kg with winter wheels.
    Put me back on my bike
    Reputation: Lombard's Avatar
    May 2014
    I had been wondering why I hear all these complaints about Cannondale's BB30, but I never had a problem with my Synapse Carbon with 7K miles on it. Never a peep. So it's only aluminum frame bikes that have the problem?
    Which is pretty much any Shimano crank. I put in a Wheels Manufacturing adapter when I swapped out my FSA Gossamer for an Ultegra 6800 crank.
    Mar 2006
    To be honest, I've never heard of Cannondale's BB30s creaking much. Most of the creaking issues I've heard of on Cannondales (or any other BB30 bikes for that matter) were when the frames used a non-Cannondale BB30 bottom bracket, like FSA- which are rubbish from my experience. As I had mentinoned earlier, I have heard it a few times on my Evo and on my CAAD10, but not often. If it is still a concern, there are several adapters on the market to convert your bike to a Shimano crank, like a couple of others have said. Wheels Manufacturing, Rotor and Praxxis are notable ones.
    Quote Originally Posted by terbennett View Post
    All BB30 bottom brackets are cartridge bearings, nothing more. It doesn't matter whether they're labeled Cannondale, FSA, SRAM...all they are are 30x37x7 cartridge bearings. If the frame they're installed in is off by the smallest amount or the bearings aren't installed exactly straight or they aren't greased or or or or...they're gonna end up making noise. If they get wet and any corrosion gets started they're gonna make noise. If you don't grease the axle when you install the crank they're gonna make noise.
    The adapter you're talking about from WM are delrin spacers that slide into the BB390 bearings and then you put the 24mm axle crank in. The BB30 bottom bracket is still installed in the frame...you're just adding another part that can possibly make noise. The best way to do it is to use a collet style bottom bracket that threads together inside the frame. I forgot to mention this in my first post.
    May 2014
    Do you mean like this one:
    https://praxiscycles.com/technology/praxis-collet/
    Reputation: Ajost's Avatar
    May 2012
    I have this adaptor on my 2012 Supersix Evo running a Ultegra 6700 crankset
    Thousands of miles with no issues
    v/r
    Ajost
    Jan 2014
    My info might be slightly out of date, but I bought a CAAD12 frameset to build up one year ago, and at the time my research showed that the adapters for the BB30 Bb will not work on the BB30a BB on the CAAD12. At the time I couldn't find an adapter that would work on the CAAD12.
    (I ended up selling the new frameset on, and passing on the CAAD12.)
    Mar 2006
    I agree but as I was saying, from what I have noticed this has been the case. Carbon and aluminum alike will have the problem. Has nothing to do with material is what I was implying in my first post. However, I have noticed this issue more on bikes with FSA. Haven't heard much from SRAM camp on this. FSA more commonly used maybe?
  1. Replies: 0
    Last Post: 07-05-2017, 07:29 PM
  2. 2016 Allez and CAAD12--what's the tire clearance like?
    By msrothwe in forum Bikes, Frames and Forks
    Last Post: 04-29-2016, 01:08 PM
  3. Any caad12 owners out there yet?
    By bjb85runner in forum Cannondale
    Last Post: 10-10-2015, 12:23 PM
  4. CAAD12 release date and pricing?
    By gti5notrkt in forum Bikes, Frames and Forks
    Last Post: 07-25-2015, 06:08 PM
  5. Nation's #1 Beast on a CAAD12?
    By MMsRepBike in forum Cannondale
    Last Post: 06-29-2015, 10:11 AM
