Results 1 to 6 of 6
    Mar 2009
    Cannondale Lefty Oliver on non-Slate frame
    I have done a lot of google searching and nothing... so here goes.... "Anyone put a Lefty Oliver road/gravel fork on a non-Slate frame?"
    There are pluses and minuses for sure, but considering it as an addition to my Ibis Hakkalugi.
    I am very curious as I tend toward gravel/adventure rides and events and am looking for some "help" on my thumb that I seriously sprained on a small bump that just seemed to work the wrong way.
    Thoughts?
    Ideas?
    Pics?
    Thanks!
    Brad
    Reputation: Lombard's Avatar
    May 2014
    The problem with the Lefty and Headshok forks is it's a Cannondale proprietary system. They are excellent suspension forks for sure, but they use an oversized headset which would not be compatible with your bike.
    In fact, I don't know if you could use any suspension fork. I really don't know what your options are other than to run the widest front tire you can fit so you can use less pressure. That will remove some shock.
    Mar 2009
    A little procrastination effort here....
    Looks like it might be possible. Interesting to see if anyone has tried this with the gains and hassles:
    https://cannondale.zendesk.com/hc/en...nnondale-bike-
    May 2014
    Quote Originally Posted by rhygin View Post
    It would probably change the geometry and handling on your bike - maybe for better, maybe for worse.
    Mar 2015
    I like the idea a lot..
    Mar 2009
    Hmmm.... found this during a conference call...
    https://project321.com/product/taper...y-1-0-adapter/
  1. Cannondale Slate: Test Ride Report
    By elvisvelo in forum Cannondale
    Last Post: 01-29-2017, 05:04 PM
  2. Cannondale Slate Recall - Don't run them tubeless
    By Migen21 in forum General Cycling Discussion
    Last Post: 04-29-2016, 05:31 AM
  3. Cannondale Slate
    By bjb85runner in forum Cannondale
    Last Post: 07-06-2015, 12:01 AM
  4. 2015 Fall: Cannondale SLATE with 30 mm Lefty Oliver Suspension Fork
    By Mergetrio in forum Bikes, Frames and Forks
    Last Post: 06-25-2015, 06:21 PM
