Results 1 to 9 of 9
    Apr 2013
    Chinese Carbon frame size?
    I am thinking about picking up one of these and putting road wheels and tires on for a disc 1x9. I'm going to put on a bullhorn, so sometimes I'll be on the tops and sometimes out on the horns. The brakes will be on the tops. I'm an average 5'9" tall. What size do you think would best for suited for me? Thanks!
    FR602 Full Carbon 3K Cyclocross Cross Bike Frame BSA Fork 51cm 53cm 55cm 57cm | eBay
    Sep 2004
    I'm also 5'9" and I've been looking at this same frame too. I want one for gravel roads and even though they have nearly a road bike BB height, I'm a little concerned about standover height which of course is not given. I'm most comfortable with a 55 TT so I fall just between their size 53 and 55. I prefer the longer head tube of the 55 but I have a hunch it's a mite too large because of the TT length. Did I confuse you?
    Apr 2013
    Quote Originally Posted by Birddog View Post
    No, not confused. Mine will be for road only, so the BB height doesn't worry me. I built a 26" MTB 1x9 from a Chinese frame. It's BB was pretty low. I just had to be careful and it wasn't a problem. I'm not to concerned about standover. But, I'm actually 1/4 short of 5'9", so yeah, maybe a little confused now. Maybe the 53 would be a better choice.
    Apr 2013
    My Santa Cruz Nickel has a 584mm top tube and it fits me perfectly, with a 90mm stem. I'll have a 100mm stem for this bike. So, yeah, I'm not sure what to do. I do like the aesthetics of smaller frames. But, I know that's not a good reason to get a smaller frame. I guess I could use like a 25mm setback post on it. But, frames that are to small are uncomfortable.
    Sep 2004
    Another point to consider is your saddle to bar drop. If your position is upright, then the smaller size with the shorter headtube will require more spacers and/or higher sloping stem. Both could make it look goofy. If you have plenty of drop, then it'll look OK.
    Apr 2013
    I did hear back from them. They tell me size 55.
    Apr 2013
    I don't mind having a more bent over position. I generally run a 5mm spacer under my stems. I'm thinking 53 and a setback post if I need it. This chart says I'm at the upper limit of 53. I'm about 175cm tall and size 55 starts at 178cm.
    Reputation: AZ.MTNS's Avatar
    Jun 2009
    Jan 2013
    Has anyone bought the fr602 frame.
  1. chinese carbon frame
    By c-lo in forum Cyclocross
    Last Post: 03-13-2015, 05:21 AM
  2. Got rid of my Chinese Carbon frame.
    By pete2528ca in forum General Cycling Discussion
    Last Post: 05-06-2013, 10:05 AM
  3. Looking for Chinese carbon frame at least 60cm
    By adam_mac84 in forum Bikes, Frames and Forks
    Last Post: 09-28-2010, 06:28 PM
  4. chinese carbon frame testing
    By stevesbike in forum Bikes, Frames and Forks
    Last Post: 01-09-2010, 02:13 AM
