Results 1 to 5 of 5
    May 2013
    Dent in Frame of Specialized Langster 2010
    I just bought this Specialized Langster 2010 from someone in London and I've recently just noticed 2 dents in the frame.
    Could anyone give me a professional opinion on whether it is safe to ride this bike and whether it will last me at least for a year?
    Thank you for looking!
    Decrepit Member
    Reputation: Scooper's Avatar
    Mar 2007
    Sorry, I thought it was a steel Langster. I deleted my comments because they aren't relevant.
    -Stan
    my bikes
    Decrepit Member
    Mar 2007
    -Stan
    my bikes
    May 2013
    Quote Originally Posted by Scooper View Post
    That's perfectly fine! Thanks for replying anyway. Being the case that the frame is aluminium what is the verdict?
    Decrepit Member
    Mar 2007
    Quote Originally Posted by gabrielaszalos View Post
    Question. Are both of the dents on the seat tube? They have the appearance of a repair stand clamp having been overtightened by a hamfisted mechanic.
    I don't believe the structural integrity of the frame is compromised enough from those dents to be a safety issue for normal riding. If both dents are on the seat tube, I would try greasing up a long seatpost (long enough so that it can be inserted with the bottom below the dents) and working it down the seat tube by rotating it as you apply downward pressure. It would help to chamfer the end of the seatpost with a file. This may smooth out the dents from inside the seat tube.
    Use a seatpost with a diameter a couple of tenths of a millimeter smaller than the inside diameter of the seat tube.
    Then, by using a long enough seatpost to get past the dents, the seatpost will reinforce the seat tube in the area of the dent.
    Just MHO...
    -Stan
    my bikes
  1. Replies: 11
    Last Post: 01-31-2011, 07:24 AM
  2. hit and run-specialized langster
    By gonzo6512 in forum Components, Wrenching
    Last Post: 08-17-2010, 05:26 PM
  3. 2010 Steel Langster
    By treehugger in forum Specialized
    Last Post: 11-11-2009, 04:54 PM
  4. new 2010 Steel Langster Build
    By treehugger in forum Fixed/Single Speed
    Last Post: 11-02-2009, 09:33 PM
  5. 2010 Specialized Langster
    By Dave Hickey in forum Fixed/Single Speed
    Last Post: 06-10-2009, 11:16 AM
