Results 1 to 21 of 21
    Nov 2015
    Dimpling chainstays for added tire clearance
    I searched around a bit and found some information, but would like some more. Has anybody added dimples to chainstays to add a little bit of tire clearance? This would be on a steel frame. I sort of impulse purchased a frame, and it doesn't quite live up to the specs. It's supposed to clear a 32, and while a 31.9mm wide tire fits and spins with about 1mm of clearance on either side, it's not really ideal. One ride resulted in rubbing paint. There's about 34mm of clearance between the stays at the widest point on the tire.
    This is before the tire swelled a bit:
    I have a 30 on it now, and it's slightly better, but I didn't buy this to run a 30.
    How realistic is it to add dimples to an already built and painted frame? Will it damage anything? Has anybody done this as a DIY? I know it'll void the warranty, but that's OK. I did come across a builder that added chainring clearance to a completed frame with shaped wood and a clamp, and that turned out well.
    Or is this one of those "sell it and buy the right frame" sort of deals?
    Oct 2013
    I would heat the steel then clamp it to bend the inside out farther. Not the best solution, but what could go wrong?
    BANNED
    Road Warrior
    Reputation: n2deep's Avatar
    Mar 2014
    Sell the frame. If you modify the frame you will also change the structural properties and increase your risk of a failure-crash, it's not worth the trouble. Pushing a bike out of the woods sucks..
    a real member's member
    Jul 2016
    i've read that people do this with a golf putter, like an old bullseye putter.
    search it.
    steel is real.
    Feb 2002
    Quote Originally Posted by Pisgah2000 View Post
    Answers in order:
    Easy to do - hammer or clamp on a shaped block of wood. If done poorly, yes. I'm sure it's been lots of times DIY. Some people actually value having the right frame, others not so much.
    Reputation: velodog's Avatar
    Sep 2007
    Here's a couple of links to conversations about the process, with photos of the tools used. Some of the experience is coming from frame builders and some from hobbiests, so a fair pool of information. It seems pretty straight forward, depending on ones ability with the use of hand tools.
    You should be able to get a clear idea on how it's done and an idea to make a tool with what you have available to you. If you search around those discussion forums you should be able to find more info.
    I think that the heat that has been mentioned is not needed, and may be a bad idea.
    https://groups.google.com/forum/#!search/dimple$20chainstay/framebuilders/IyZJkCQRLDE/YcXgSeHXFAAJ
    https://groups.google.com/forum/#!search/dimple$20chainstay/650b/z6jRzSNIr5k/62CjPu29MHYJ
    Too old to ride plastic
    I'd ask a reputable frame builder about it.
    I would assume the tubes used would impact the answer. So even strangers on internet who might actually know for sure, wouldn't with that information missing.
    Nov 2015
    Thanks for the feedback. I do worry about damage and potential early frame failure, especially at that part of the frame. That's the only place where I've cracked a steel frame (several years after damage that was similar to what adding clearance would do).
    The DIY option looks doable, but it feels a bit half-assed. I assume that I'd then need to get the frame alignment checked as well.
    I may just sell it and buy the right frame.
    Also, I have no idea why this has the exclamation icon next to the title.
    gazing from the shadows
    Jan 2003
    If you like everything else about the frame, asking for quotes from frame builders seems like a reasonable thing to do before making that call.
    I would say given the cost of alignments and tube replacement (sample prices: Bilenky Cycle Works ) it shouldn't be very expensive at all. Likely less than you would lose on selling the frame used, even getting a good price on it.
    Worth a few e-mails and phone calls, again, if the frame is good for you in every other way.
    Happily absent RBR Member
    Reputation: Kontact's Avatar
    Apr 2011
    I wouldn't do it on heat treated or air hardening steel - 725, 753, 853, Ox, etc. Like trying to bend a knife blade.
    Nov 2015
    Quote Originally Posted by QuiQuaeQuod View Post
    I like most things about the frame, but I'm not sure it's worth spending probably a couple hundred bucks + shipping to modify it. Thanks for the Bilenky link - I forgot about them. I'll see what the actual cost is and go from there.
    Quote Originally Posted by Kontact View Post
    The main tubes are 520, so I don't think that's a worry.
    Reputation: Lombard's Avatar
    May 2014
    That is what I would do. No sense trying to fit a round peg into a square hole. Get the right frame for the job, IMHO.
    -- Warren Buffett
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    A possible option, depending on the details of the frame and components...is doing a 650B conversion.
    May 2014
    Hmmm. I like this idea! 650b wheels and tires will give you more room to run wider tires. I would try this before deciding to change horses.
    Keep in mind that a 30x700c is around the same diameter as a 47x650b.
    -- Warren Buffett
    Oct 2013
    Having another set of wheels that don't pair up with anything doesn't seem like a very good option.
    BANNED
    Nov 2015
    I have thought about that as well. Ultimately, what I'd like here is one bike to replace my road bike and my rough-road bike, so I'm not sure 650 is the way to go.
    I got quotes from a couple of places to dimple and align. The cost isn't too bad. $100 for the steel frame, and just for the hell of it, I got a quote for turning my Lynksey Cooper road frame into a road+ frame. $150 to dimple, $350 to raise the brake bridge for medium-reach brakes. That'll only get a 30 though (takes a wide 28 now, limited by the caliper), so not really worth it.
    Anyway, I'm leaning towards getting a Gunnar Sport and a 1x11 Force drivetrain. I'm a bit pissed that the frame I just bought wasn't quite what is was supposed to be, but **** happens, I guess.
    Sep 2007
    This is the thing, as much as I'm a 650b guy, if the 30mm 700c tire doesn't fit between the stays I don't see a 650b\47 fitting. And even a 38mm 650b will probably be hard pressed to fit in there without altering the stays.
    I think altering the stays is a workable solution, on an older used bike, but on a new bike I don't know that I'd want to change things.
    Sep 2007
    That $100 to dimple the stays may be worth it. Did you ask if the paint will hold up at the dimple, or flake off from the movement?
    Have you talked to the manufacturer to see what they have to say about the bike not meeting ability of taking the claimed tire size?
    Jan 2005
    Well it sort of was, from what you've said.
    Tires vary in width in the same size class...and the plethora of rim widths cause more variations in sizing. I read "maximum clearance" statements on frames as "LOL hope you don't have any sand or gravel stuck to your tire"....unless there are reviews with specific tire/wheel combo examples showing comfortable clearance. Particularly on rim-brake frame/forks The difference even then between a 34mm tire and a 31.9mm tire is only a mm per side--which is within tolerance of the tire alone.
    If you throw in the towel on making this frame work for what you want--at least these days there's no shortage of stock models...not shortages of frame/forks you can build up to get exactly what you want. Course, depends on your budget and wants and time frame.
    May 2014
    Understood. I was just mentioning the similar diameters. A 38x650b would probably fit even though there are no guarantees it will. Best thing would be if the OP has a way of testing out someone else's wheel and tire (bike shop??) to see if it will work.
    -- Warren Buffett
    Nov 2015
    Yep, it sort of was, sort of wasn't. I certainly could have done a better job of checking instead of just calling a bike shop and asking what fits and reading things online. But hey, it was an impulse purchase and I have a recent history of pretty questionable bike purchases. So, I'm not surprised. Heh.
    The bike came with 30s, but they measure around 28mm in reality and fit fine. Since advertised tire width has too many variables to really be useful when dealing with tight tolerances, what would be very helpful is if frame manufacturers would just list the measured chainstay clearance at 340mm or whatever (the Gunnar Sport has 43mm of clearance there, for those wondering). That would at least solve half of the problem. If I'd known that this frame only had 34mm of clearance, I probably would not have purchased it. Again, I probably could have dug around or tried to get an answer from the manufacturer, but I didn't.
    As for the other suggestion about contacting the manufacturer about the discrepancy, I imagine it'll be the argument above. All tires are different, no guarantees.
    Either way, I got the bike/frame at a solid discount, so it shouldn't be too much or any out of pocket when it comes to selling.
  1. Replies: 10
    Last Post: 11-26-2011, 06:57 PM
  2. Tire clearance (Will Cross Tire Fit?)
    By BlueMasi1 in forum Bikes, Frames and Forks
    Last Post: 10-03-2006, 03:44 PM
  3. Merckx carbon wrapped chainstays
    By Gripfer in forum Merckx
    Last Post: 05-22-2004, 08:44 AM
  4. Polar Power meter and TCR Chainstays!
    By KATZRKOL in forum Components, Wrenching
    Last Post: 03-15-2004, 07:56 PM
  5. C40 without the Hole in the Chainstays
    By Ken in forum Colnago
    Last Post: 02-08-2004, 10:19 AM
