Results 1 to 5 of 5
    Nov 2014
    ? find brake adjust screw
    Hi,
    Anyone know where I could find a brake adjust screw? I lost one of mine. Or a DIY solution?
    Pics of the screw and brake:
    Attached Thumbnails Attached Thumbnails ? find brake adjust screw-2017-09-05-22.54.31.jpg   ? find brake adjust screw-2017-09-05-22.51.46.jpg
    Dec 2006
    If you're not fussy about whether you get an exact match (that certainly looks like an off-brand brake), you can probably use a derailleur limit screw. If the derailleur limit screw is too long, you can file, cut, or use a bench grinder to shorten it, then by filing the end flat you'll restore the threads.
    Or, take the replacement screw to a hardware store and buy a matching metric nut. Maybe buy the screw there, too. Thread it on before cutting the screw. Removing the nut after cutting will restore the threads.
    Any bike shop should have a box of broken derailleurs and could give you a screw.
    a real member's member
    Jul 2016
    looks like a barrel adjuster screw. if so, you've cut it out of the two pics of the brake.
    i'd go to the bike shop in town that has a bin of used brakes and a bin of screws/bolts/nuts.
    'brifter' is a lame word.
    Quote Originally Posted by blackfrancois View Post
    It's not. It's the one that holds the end of the spring.
    I work for some bike racers
    and a bunch of skateboards
    Nov 2014
    yes, that one
  1. Adjusting Campagnolo rear derailleur - no B screw or H screw
    By Glyndwr in forum Components, Wrenching
    Last Post: 03-04-2016, 05:42 AM
  2. Please help with part. Need specific screw and can't find it.
    By smoothie7 in forum General Cycling Discussion
    Last Post: 03-12-2015, 09:54 AM
  3. trying to find a seller for this set screw
    By loona in forum Components, Wrenching
    Last Post: 11-10-2012, 01:06 PM
  4. Derailleurs: Limit Screw and B-Screw adjustments
    By RyKnocks in forum Components, Wrenching
    Last Post: 04-13-2012, 05:41 PM
  5. Missing screw for Deda Newton stem - where to find one ??
    By Pierre in forum Components, Wrenching
    Last Post: 11-21-2005, 07:08 PM
