Results 1 to 12 of 12
    Reputation: musicociclista's Avatar
    Jan 2006
    Geometry Data for Lemond Victoire
    Hi, I have an opportunity to buy a 05 or 06 (not sure) Lemond Victoire (Ti-Carbon) size 53 cm, but can't find a geometry chart anywhere. I know the top tube is 54.5 cm but would like to know the seat angle and head tube angle measurements. Anyone with a geometry chart will be highly appreciated. Thanks!!!
    Old Skool
    Reputation: Stogaguy's Avatar
    Feb 2006
    Thumbs up E-mail me
    I just asked Trek a similar question. They e-mailed me the complete 2005 specs manual for all of their brands. It is a 237 page PDF. E-mail me and I would be happy to send it to you
    The avatar is not me; just cool and suitably old skool.
    Sep 2005
    this is for the 2007-8 carbon series:
    seat tube angle and head tube angle both 73 degrees
    Jan 2006
    Sa: 73.3; Ha: 73
    Apr 2008
    I had an 05' Lemond Versailes (steel/carbon spine design) in 53cm. Im 5'6, it was way too big for me. the lemonds are a weird fit for a bike. Id ride it first for a lengthy test ride just to make sure. Theyre really nice bikes but they are a strange fit so be sure. I actually sold mine to a friend and he absolutely loves it. The bike looks great with brooks saddle/bartape and some gumwall tires.
    Jan 2006
    I'm 5'9" and have a small Giant TCR (53.5 tt) and a medium TCR (55.5 tt) and the 53 cm Victoire is 55.4tt so I'm guessing I'll be ok on that size. I feel a little stretched on the medium TCR with a 100mm stem... maybe the Victoire with a 100mm stem will fit me the same as the small TCR ( I use a 110mm stem) I'll let you know if I test the bike.
    Reputation: boneman's Avatar
    Nov 2001
    Hopefully you can read it here
    If not, send me a PM and email address and I'll sent it to you.
    Quote Originally Posted by musicociclista
    i've got limited minutes left in life, don't waste my time
    Nov 2001
    51 would be probably best
    I'm 66.5" with a 30" cycling inseam and ride a 51cm Maillot Jaune. It fits perfectly with a 100mm stem. I find them (Lemond's) to be fairly conventional in their geometry as it relates to relative lengths between TT and ST, angles, etc. If the shop told you a 53 was the right size, one wonders about their fitting knowledge unless your proportions are really unusual. Hope you got most of you investment back. What's the replacement?
    Quote Originally Posted by B15serv
    Attached Thumbnails Attached Thumbnails Geometry Data for Lemond Victoire-dscn2477-large-.jpg
    Jan 2006
    Quote Originally Posted by boneman
    According with the Lemond info I've found (thanks Stogaguy!!!), a 5'6" rider will ride a 51cm.
    J24
    J24 is offline
    J24
    Oct 2003
    Traditional Lemond geometry with slack angles, long top tube, is different from most bikes and not a straight up comparison to your other bikes, and you ougth to ride one first.
    I had a 53cm Lemond Alpe d'Huez, and nothing wrong with the bike except the geometry wasn't right for me; but I have friends who love theirs going back to Lemond after trying Lightspeeds, Treks, Canondale, Cervelo.
    Loves to Suffer
    Reputation: Zipp0's Avatar
    Aug 2008
    53cm Lemond Tourmalet here. I am 5'11" with a longer torso and 30" inseam and the bike fits me perfectly.
    Apr 2006
    Wow, some of you fit really small frames! I'm 6"0" saddle height at 78.1 cm per high quality fit session, and I'm very comfortable on a 59 cm spine. Running my seat all the way back on a 20mm setback post, with a 120mm -7 stem using 20mm of spacers for a 5-6 cm saddle-bar drop.
    The chart would have me on a 55 or 57, albeit with a +17 stem. I can't imagine going smaller as the SA gets steeper and the stem rise would require a much longer stem to keep the reach I have now. Hmmmm.....
