Results 1 to 4 of 4
    Sep 2011
    Looking for steel road frame for Interal Gear hub under $500
    There aren't very many hills in my part of the city so I am tempted to build a steel frame bike with a single crank and an internally geared hub. Leaning away from a fixie just in case, plus I am not in very good physical shape currently... Would really like to use the Shimano Alfine 8spd. Can anyone suggest a frame that will fit that rear hub? I know I need 135mm backspacing but most road frames I have seen are 120-130mm. I don't want to spend more than $500 and looking for something that is lightweight. Also would prefer something with a straight blade steel or carbon fork.
    Thanks
    B
    Militant commuter
    Reputation: SilverStar's Avatar
    Jan 2008
    Have you looked at the Soma "Roadie" frames and/or Surly (Pacer and possibly others)? Or how about a Salsa Casseroll? All of those come in around the pricepoint you're looking at, if I recall. None are particularly lightweight...but light enough.
    "Luminous beings are we...not this crude matter!"
    PSC
    PSC is offline
    Mar 2004
    Here you go:
    Civia Cycles
    Universal Cycles has the frame for $495 and complete bikes for $1295 for complete 8spd bike.
    Sep 2011
    Are you looking to build this up because you've already got the hub? Any specific reason you want to go steel? I ask because the Raleigh Cadent i8 might fit perfectly with what you want outside of the fact that it is an alumninum frame with a carbon fork. REI had these the other week onsale for ~$600.
  1. Building up old steel road frame: bb options
    By SlowMover in forum Components, Wrenching
    Last Post: 04-28-2011, 01:15 PM
  2. New Steel SS Road Frame
    By jtompilot in forum Specialized
    Last Post: 05-27-2009, 07:33 PM
  3. What Headset fits steel road frame?
    By Jayzonk in forum Components, Wrenching
    Last Post: 05-27-2009, 04:50 PM
  4. Looking for a nice Steel road/cross frame
    By averen in forum Bikes, Frames and Forks
    Last Post: 04-13-2008, 12:55 PM
  5. 2.7# light steel road frame from Viner
    By TrailNut in forum Save Some Weight
    Last Post: 03-18-2005, 01:16 PM
