Results 1 to 10 of 10
    Sep 2006
    Mileage on Campy Chorus Cassettes
    Hi,
    I know that it varies considerably but what are you averaging for mileage before replacing the cassette?
    Thanks
    (I meant to post this in the Parts, components forum)
    Feb 2002
    Quote Originally Posted by Lookbiker View Post
    Hi,
    Thanks
    I use Centaur cassettes (no advantages to higher level cassettes) and get about 20K miles on them. But as you point out there are a LOT of variables so you will not really learn anything from the responses you get to your question.
    Feb 2012
    My record keeping stinks but to me my record and chorus cassettes get better mileage, appear to be more finished (what ever that means) and shift smoother than the lower level lines, however I must admit it might be due perception only. Also that fraction of a pound weight savings could possibly be important to me in rocketing away from a stop or climbing a mean incline.
    Reputation: Ventruck's Avatar
    Mar 2009
    Eh, was OP talking about Chorus 10 or 11?
    Sep 2006
    Using Chorus 11.
    Feb 2013
    You can get 20k+ miles from them, *if* you are diligent about measuring the chain and replacing it when it is stretched even a little, and cleaning and lubing and wiping off the chain. As the chains stretch they will wear the teeth to a sharp point, when that happens the cassette and likely the chainrings are done. Also, sand/dirt in the excess oil on the chain accelerates this process. Lastly, keep everything adjusted well, driveline noises are bad for cassette life.
    Aug 2008
    I tend to get 3 to 4 chains worth out of each cassette.
    Not Banned
    Reputation: atpjunkie's Avatar
    Mar 2002
    depends on how often you clean / change your chain honestly
    one nation, under surveillance with liberty and justice for few
    still not figgering on biggering
    Feb 2002
    Quote Originally Posted by Easyup View Post
    When comparing Veloce' and Record cassettes, I find no difference in shifting or noise. The Record cassettes certainly do wear out faster (assuming you spend significant time on the Ti cogs). YMMV
    Mr Dopolina
    Reputation: Bob Dopolina's Avatar
    Nov 2008
    Quote Originally Posted by JoelS View Post
    +1.
    That's somewhere around 15,000km. I live where there are big mountain with lots of climbing and lots of rain (seasonal).
    BDop Cycling Co., Ltd.
    www.bdopcycling.com
