Results 1 to 5 of 5
    Sep 2005
    Mixing Force and Apex Question
    I am building up an old steel road frame with SRAM 1x.
    Want to keep the mechanical rim brake calipers so it appears that I have to go with Apex 1 shifter and RD. (Force is only hydraulic?)
    The question is: Can I use Force 1 rear cassette and Force 1 crankset with the Apex 1 RD?
    Darling of The Lounge
    Reputation: Retro Grouch's Avatar
    Apr 2002
    Sep 2005
    Thanks!
    Now, if I can only figure it out.
    'brifter' is a lame word.
    Quote Originally Posted by boltzmann View Post
    Yes. All SRAM stuff is the same cable pull ratio. You can use 10 and 11 speed interchangeably and any level.
    ETA: As long as the shifters match the cassette, ie: 10 and 10, 11 and 11. Obviously use the appropriate chain.
    I work for some bike racers
    and a bunch of skateboards
    Sep 2005
    My original assumption may have been wrong. SRAM doesn't list it on their Force 1 page but Competitive Cyclist has Force 1 mechanical brake/shifter levers (https://www.competitivecyclist.com/s...speed-shifters).
    So it appears that I can go 100% Force 1 and keep the mechanical brakes
  1. Replies: 1
    Last Post: 08-08-2012, 07:26 PM
  2. Tarmac Elite Apex or Allez Comp Compact M2 Apex?
    By tracerprix in forum Specialized
    Last Post: 07-19-2011, 05:31 PM
  3. Mixing Sram apex 11-32 cassette with Shimano Xt...
    By Ventura Roubaix in forum Components, Wrenching
    Last Post: 12-20-2010, 01:05 PM
  4. When are SRAM Apex bikes coming out? When are the SRAM Apex groups being sold?
    By Stu_the_weak in forum General Cycling Discussion
    Last Post: 07-26-2010, 11:01 AM
  5. Mixing and matching Red and Force
    By hayaku in forum SRAM
    Last Post: 02-18-2008, 05:43 AM
