Results 1 to 24 of 24
    Dec 2009
    Pegoretti Duende
    Duende
    Jul 2008
    very elegant ride...
    maybe go thomson x2 stem to match the seatpost?
    who made the fork?
    Dec 2009
    It's a Pegoretti fork.
    Reputation: Nielly's Avatar
    Sep 2009
    Very nicely proportioned for a smaller frame size. You wonder that other builders can't acheive the same result - I would imagine it is custom sized, no?
    Dec 2009
    Quote Originally Posted by Nielly
    Stock geo and paint. 48cm
    I think most builders would go slopping on such a small fame. He doesn't.
    Reputation: onlineflyer's Avatar
    Aug 2005
    Sweeeeeeeeeet! Now we need a ride report.
    If you focus on the past, you will never see the future.
    Every day I wake up is a good day!
    "I don't need another bike"
    - Anonymous
    Reputation: Kuma601's Avatar
    Congrats! Very nice bike!
    Reputation: rcnute's Avatar
    Dec 2004
    Perfect. Wouldn't change a thing!
    I saw a werewolf drinking a piña colada at Trader Vic's, his hair was perfect. (Warren Zevon)
    Fake President
    Reputation: SystemShock's Avatar
    Jun 2008
    Very drool-worthy.
    What's it weigh with pedals? How's the ride and handling?
    Would also be curious as to what seat tube angle he used on such a small frame.
    Monkhouse: I want to go like my Dad did – peacefully, in his sleep, not screaming in terror like his passengers.
    System: Fake news?? Trump's a Fake President, for God's sake.
    Plat: I'd rather fellate a syphilitic goat than own a Cervelo.
    Homer: I believe that children are our future. Unless we stop them now.
    Seam: Saw Bjork poop onstage back in the day. It blew my teenage mind.
    Dec 2009
    Quote Originally Posted by SystemShock
    Very drool-worthy.
    74.5 STA
    I own a steel bike with a steel fork. It should be obvious I don't care or have a clue of it's weight.
    Dec 2009
    Quote Originally Posted by rcnute
    Thanks. If I win the lotto, I'll splurge for a 29.4 WR post.
    Aug 2009
    Quote Originally Posted by ComesAtime
    If he did, then maybe your entire seat post would show (well, technically, it does, but...) and there wouldn't be nearly as much head tube distance above the top tube.
    Dec 2009
    Quote Originally Posted by Pancho's Balls
    There is more post in the frame then out of it. Not sure what you're seeing. All his frames have a tall headtube. I guess you are new to Pegoretti.
    Reputation: ultimobici's Avatar
    I think most builders would go slopping on such a small fame. He won't.
    Fixed it for you.
    To quote him - "The name on the frame is P-E-G-O-R-E-T-T-I, if you want sloping, buy a Giant!"
    Dec 2009
    Quote Originally Posted by ultimobici
    Fixed it for you.
    Please fix things your 100% sure about. He will
    Sloping...........
    Sloping...........
    Should have added ....
    "unless the geometry demands it." Evidently, that Fina Estampa required it whereas the Marcelos don't. The second frame could be level.
    The quote was first hand in 2002, in Caldonazzo.
    Nov 2009
    have a look,he seldom build slop frame
    Dec 2009
    The Marcelo is sloping..
    Well, if it was requested rather than a geometric requirement, then it appears Dario's principles are not as strong as they used to be. He'll probably start building with carbon stays before too long!
    If that is the case, I'm glad I no longer sell them.
    Dec 2009
    They are 46cm frames and required. I'm sure he is suffering the lose of your patronage.
    I did say if. Bearing in mind the passion with which he dismissed both sloping top tubes and carbon stays, I'd hope he'd still be true to his word. Seems the old bugger is. Good thing too.
    Badger
    Reputation: st3v3's Avatar
    Jul 2009
    The fork on that thing owns. I must say, however, I'm slightly annoyed about "Handmade in Italia." If you want it to have true Italian flavor, don't say "handmade in ____." Just my thoughts.
    Do work.
    Reputation: Frith's Avatar
    Oct 2002
    That is a beautiful bike there is no doubt about it.
    I have to say though that in my opinion it would be better balanced aesthetically if the top tube were joined to the head tube just a touch higher and it did have a slight slope to achieve the same standover height.
    I don't really get the idealistic top-tube-must-be-level-by-all-means thing... I do prefer a level TT as well but sometimes a little bit of slope can help balance the bike out visually. Seems obvious that this is one such example.
    Beautiful build none the less.
    Quote Originally Posted by st3v3
    Far from it. It is very common to have English on products, vehicles etc in Italy. Makes it exotic sounding apparently.
    An Italian friend of mine had a Look with Dura Ace & FSA all over it. Replaced it with a Wilier Le Roi dripping in Record because he lives in the UK and "it is necessary here, but the Look is exotic in Italy". Contrary to popular belief Campagnolo is not omnipresent in Italy, if anything SRAM was more evident in Laigueglia last weekend! Go figure!
