Results 1 to 25 of 25
    Nov 2017
    Question on Carbon Forks
    One of the reasons I hear from people on why they choose carbon for bike frames, is stiffness of carbon fiber. Most road forks I see these days are carbon fiber and also straight, with virtually no taper, as compared to steel forks of the past that had some rake (curve at the end) to them and were thinner towards the dropout. The rake and tapered design was to allow some flex in the fork to absorb road shock.
    My question is how much road shock is transmitted to the rider through carbon forks as compared to raked, tapered steel forks? Will I need extra padding in my bar tape? I do not advocate wet spaghetti for forks, but I am wondering about the feel of these forks.
    There is no answer to your question. Like steel forks, knowing what they are made of doesn't say how they ride.
    'brifter' is a lame word.
    The shape of the fork leg (curved or straight) has little to do w/ how it absorbs rock shock. As for your question...no one here can answer it.
    I work for some bike racers
    and a bunch of skateboards
    Happily absent RBR Member
    Reputation: Kontact's Avatar
    Apr 2011
    Classic steel road forks are about as stiff and punishing as forks commonly get, though some carbon forks can be close.
    This article is old, but the cluster of steel forks at the extreme of minimum deflection compared to every carbon and aluminum fork at that time should be illustrative:
    https://www.sheldonbrown.com/rinard/..._forktest.html
    The Tange Silhouette shows that steel can be made a bit softer, but most steel forks are going to be the least soft riding forks for both deflection and vibration damping.
    Jan 2014
    For what it’s worth: most carbon forks today are NOT straight - they do have rake, usually 40 to 45mm
    They look straighter because of their design, but if you look closely you can see clearly that the fork does not extend along the same angle as the head tube. It’s just deceptive because instead of going out straight and then turning lower down, the rake angle starts immediately at the bottom of the head tube.
    Apr 2011
    Quote Originally Posted by fronesis View Post
    That is generally not what is meant by straight vs curved fork blades. Straight refers to the blades, not the whole fork.
    Jan 2014
    Quote Originally Posted by Kontact View Post
    Fair enough. But I was replying to the OP, who wrote this:
    I therefore took him to be suggesting that carbon forks have no rake.
    I had also thought, but maybe I was wrong, that the whole point of the curve in a steel fork was to create the needed rake. But maybe steel forks were curved for some other reason that I don’t understand.
    Apr 2011
    Curved fork blades go all the way back to early bikes. I would imagine that early forks were likely less likely to fail at the crown if the blades where pre-bent to get the flex to occur away from the highest stress areas. The later fork materials were reliable enough to not need this hedge.
    Reputation: Lombard's Avatar
    May 2014
    First and foremost, your tires will have more to do with the quality of your ride than anything else on the bike. There is a very good reason Mr. Dunlop invented the pneumatic tire 130 years ago which we still use today:
    https://en.wikipedia.org/wiki/John_Boyd_Dunlop
    They act as mini shock absorbers better than any other part of the bike except your own body.
    My best guess as to why carbon appears to be the material of choice for forks on both aluminum and steel bikes is the advent of disc brakes. Because of the extra stresses during braking with disc brakes, forks have to be beefier than on older rim brake bikes. If you did this to a steel or aluminum fork, it would add significant weight and would not be marketable in the weight obsessed road biking culture.
    Jan 2014
    Makes sense.
    Quote Originally Posted by Lombard
    I think the switch to carbon forks pre-dates the massive switch to disc brakes, and I think the explanation is weight. A fully cro-mo road fork weighs around 1,000 grams – that's MORE than a light aluminum or carbon FRAME. Today's full carbon road forks can weigh as little as 300 grams.
    Feb 2002
    Correction: The shape of the fork leg (curved or straight) has NOTHING to do w/ how it absorbs rock shock.
    May 2014
    You are correct about carbon forks on non-carbon bike frames predating disc brakes. However, aluminum and cro-mo forks were still common until disc brakes came on the scene for the reasons I stated that disc brake bikes need a beefier fork. Imagine how much a cro-mo fork designed to be strong enough for a disc brake bike would weigh. I don't know that one exists.
    Nov 2015
    ^ There are lots of steel disc forks out there. They're plenty strong, and as far as I know, don't weigh any more than the rim brake steel forks. Carbon forks are more popular now because they're significantly lighter and not a whole lot more expensive.
    When it comes to ride quality, like has been said, material has little to do with it. I have a very comfortable and compliant carbon road fork, and I have a quite stiff and uncomfortable carbon road fork.
    Jun 2004
    Quote Originally Posted by Pisgah2000 View Post
    Steel disc is going to weigh more than rim if only as there's more material for the disc mounting tabs, as well as they generally beef up the fork to accommodate different braking forces at the hub. No idea how much more it weighs and since it's steel with a likely steel frame, I doubt it matters much as you're generally not counting grams at that point.
    Apr 2011
    Nope. Carbon forks where common for decades before disc brakes, and disc forks are commonly steel and aluminum. Disc carbon forks are heavier than carbon rim brake forks.
    Aug 2013
    Seems to me that carbon forks became common in the mid to late 90s (about the time 9 speed came out). Way before disc brakes.
    May 2014
    Likewise, I have two different carbon road bikes. One is laterally stiff, the other one feels like a noodle.
    Apr 2011
    Quote Originally Posted by crit_boy View Post
    Kestrel introduced the EMS carbon fork in 1989, but it took a few years before other companies started offering it on their bikes. It pops up as an option in the 1994 Litespeed catalog. They probably would have caught on earlier, but the SR Prism aluminum fork came out about the same time and was about the same weight and less costly. So it was the mid-90s before most folks came across them.
    Apr 2011
    Looking at listings for disk and regular forks on weightweenies, I'd say the weight penalty to add discs is very similar for carbon, steel and aluminum forks.
    Mar 2006
    Let's be real here. Most people ride carbon bikes because they were told that carbon is the best and because the pros ride it. As for forks, most bikes come with carbon forks, a steel fork can have the same ride quality, but it will weigh a bit more. That's just simple logic. Kerry Irons is right though. The shape of the fork leg (curved or straight) has NOTHING to do w/ how it absorbs rock shock.
    Mar 2006
    I remember that fork! It was actually a nice fork.
    Apr 2011
    Quote Originally Posted by terbennett View Post
    I don't see the logic in claiming that steel forks ride as softly as the alternatives when it isn't true.
    Mar 2006
    I still believe it a steel can be compliant and ride as softly as the alternatives...except maybe carbon.
    The Rinard Fork Deflection Test
    Nov 2017
    OK, it is purely a subjective call, and it is possibly subject to other factors, but after about 200 miles, I feel the new bike with carbon forks, is sending less vibration to my hands than my previous bikes.
    This is, as I said, purely subjective, but I've traveled the same sections of road with my all steel Gilmour. my aluminum Ghost Panamao (with front non-pneumatic shock), and now the Lynskey with the carbon Gravel fork. I felt less shock through the Lynskey than the other two bikes. Just for the sake of completeness, both the Gilmore and Lynskey are running 700c x 28mm, while the Ghost has 700c x 35mm tires and all tread designs are non-off road, and all tires are pumped to road pressures.
    For comfort, personally, I would rate the bikes most comfortable to least, as Lynskey, Ghost, and Gilmour. That comfort level I'm talking about is handlebar vibration exclusively. Overall comfort, say on a long ride, is not be discussed here, just handlebar vibration being transmitted to my hands.
    Apr 2011
    Since you are referencing the Rinard test, which puts the aluminum and carbon forks in the compliant category and most steel forks not so much, which alternative are you referring to?
    A few days ago I built up an early '90s Raleigh with a steel unicrown fork. It handles really nicely, but damn that skinny fork is stiff. I pulled the wheels with 25c tires off another bike with a fairly soft Icon fork, and it felt like I was on 20c tires again.
  1. Replies: 25
    Last Post: 12-12-2013, 11:27 AM
  2. Track Forks vs Road Forks
    By brandongouge in forum Fixed/Single Speed
    Last Post: 02-18-2009, 08:25 PM
  3. Ritchey Pro Carbon and WCS Carbon forks
    By SickBoy in forum Bikes, Frames and Forks
    Last Post: 11-22-2006, 08:02 PM
  4. carbon forks: full carbon vs. one with alu crown and steerer
    By DaveloMA in forum Bikes, Frames and Forks
    Last Post: 01-05-2006, 03:06 PM
  5. Forks forks forks
    By AlanS in forum Bikes, Frames and Forks
    Last Post: 06-13-2005, 08:53 AM
