Page 2 of 2 FirstFirst 12
Results 26 to 29 of 29
  1. #26
    Reputation: Nicole Hamilton's Avatar
    Sep 2010
    Quote Originally Posted by DrSmile View Post
    Can you get framesets like this with sloping top tubes/compact geometry?
    If you're getting a SS frame made,I think you're already talking custom, so it doesn't seem like this should be a problem unless Reynolds simply doesn't make tubes in the appropriate length. If you have an idea for a bike you'd like to build, I'd reach out to a framebuilder you like and ask what he can do for you.
  2. #27
    Matnlely Dregaend
    Reputation: DrSmile's Avatar
    Jul 2006
    Quote Originally Posted by gordy748 View Post
    Going slightly off piste, I used to find compact bikes gimpy looking. Then I owned 2 compact frames in a row. Now I have a standard bike that looks a little... gimpy looking.
    I have to say this is exactly my experience as well. I had regular frames and they never bothered me until I got some compact ones. Now my regular frames just look "odd." Which is the only reason I asked about a compact frame.
    _______________
    "I haven't @#&$ed like that since I was an altar boy."
  3. #28
    Apr 2011
    I realize the following question is sacrilegious: Can you get framesets like this with sloping top tubes/compact geometry?
    Luckily, Pegoretti refuses to make compact road frames.
  4. #29
    old school drop out
    Reputation: laffeaux's Avatar
    Dec 2001
    The 931 tubing sounds pretty ideal for my purposes, Reynolds also claims better corrosion resistance which makes sense as it's 17% chromium. Does anyone have a frame made of 931? I realize it's fairly new to market.
    Thanks for the info on the 931 tubes. I'd not heard of that Reynolds had come out with it. From a bit of on-line reading it sounds promising for bringing down the cost of stainless frames - cheaper tubes and less labor and tolling costs.
    I have a 953 Indy Fab CX frame that I bought used and have owned for about two years. Mine has a slightly sloping top tube, and I'm sure that a builder can build as much slope as you need/like.
