Results 1 to 8 of 8
    Jun 2011
    Replacing internal tubing on a Focus Izalco
    Just replaced the inner and outer cables on my Focus Izalco, but shifting is very stiff. I think the internal tubing (liner) needs replacing. I already managed to replace the tubing for the front derailleur cable, but am still struggling with the rear. How do I get the tubing out? Can I access it from the bottom bracket? Any tips?
    Forever a Student
    Mar 2014
    What is your method for cutting and preparing the ends of the housing?
    use a torque wrench
    Jun 2011
    Cutting was done using a Parktool CN-10 cable cutter. Ends opened up with a nail and filed. If I run a full length housing from shifter to derailleur (external to the frame), it shifts very smoothly.
    Jun 2011
    I think I found what the problem is. Apparently, the housing needs to be installed without a ferrule at the frame exit near the rear derailleur. Can anybody confirm this? After installing the housing without a ferrule, it shifts smoothly... It seems that the cable with ferrule does not fit well in the frame exit, leading to a misalignment between inner and outer cable...
    'brifter' is a lame word.
    99.9% of the time you'll need ferrules when running shift housing into and out of frames. Very few exceptions to this, a few but not many.
    I work for some bike racers
    and a bunch of skateboards
    Apr 2012
    I used ferrules on my Ergoride. I haven't tried replacing the liners (think I would go Etap first) but I don't see that when I had the BB out it provided any particular access to the tubing. My FD can be a little stiff (doesn't always like to return when shifting to the inner ring) and I suspect the bend at the BB in the liner tube might be an issue.
    Another thing is there is 1.1 and 1.2 mm shift cable. SRAM says to use 1.1 but I bought a cable kit (Yokozuna) and found out it provides 1.2. which I installed. So that may make a difference too (haven't bothered to get some 1.1 cable to compare).
    scott s.
    Quote Originally Posted by scott967 View Post
    scott s.
    You haven't replaced the housing?
    Jun 2013
    Quote Originally Posted by way2go View Post
    My Izalco has a ferrule there. It's always shifted fine.
  1. Focus Izalco Expert
    By clbess in forum Bikes, Frames and Forks
    Last Post: 03-30-2014, 08:12 PM
  2. 2011 Focus Izalco Team 1 vs. 2012 Focus Izalco Pro 3.0
    By mikesjo in forum Bikes, Frames and Forks
    Last Post: 06-28-2013, 03:07 PM
  3. Focus Izalco Team Replica or stick with my $2,000 goal?
    By diddy2003 in forum Bikes, Frames and Forks
    Last Post: 05-21-2013, 03:24 PM
  4. Opinions on the Focus Izalco Team Replica ?
    By roubaix_sj in forum Bikes, Frames and Forks
    Last Post: 06-12-2011, 09:15 AM
  5. Focus Izalco Team Milram '09
    By toaster in forum Other Builders
    Last Post: 12-30-2009, 06:48 PM
