Results 1 to 25 of 47
    Jul 2006
    Road Bike w/ a Long Head Tube - Suggestions?
    I currently own an '04 Trek 1000 that I Iike except for the short head tube. As a result, I have to stack the spacers pretty high in front for a comfortable fit. Any suggestions? I'm not picky about frame materials, name brands, or prices just yet. I just want something that doesn't require too many spacers in front. Thanks.
    Nov 2006
    Ridley has long-ish headtubes.
    You may want to look at a Specialized Roubaix or Trek Pilot too, as they have a bit longer headtubes and are a bit more relaxed.
    Cycling induced anoesis
    Reputation: PJ352's Avatar
    Dec 2007
    The Spec Allez HT length would be closer to what you have now, so depending on how much of a change you're looking for, it may or may not be an optimal choice. Felt Z series, Giant OCR's, Madone 4.5/ 4.7, and upper end new Madone (performance) models would all have slightly longer HT's than the Allez.
    Windrider (Stubborn)
    Reputation: Len J's Avatar
    Price range?
    New or used?
    Size...& what do you consider a long Head tube?
    How much do you weigh?
    Len
    "Evil....is the complete lack of Empathy!"
    ""We are what we repeatedly do. Excellence, then, is not an act but a habit. " Aristotle
    No one is as bad as the worst thing they have done & no one is as good as the best thing they have done.........think of that when you feel like you understand someone.
    Reputation: akrafty1's Avatar
    Apr 2006
    Lemond Triomphe series, or the new Madone performance fit(30mm longer head tube than the pro). Both are fantastic bikes.
    desert smouth
    Mar 2003
    Specialized Roubaix is what you want.
    I love these absolute recommendations without knowing his budget.
    Would you change your recommendation if he said his budget was $7,000 for the full bike?
    LOL
    Len
    Steaming piles of opinion
    Reputation: danl1's Avatar
    Quote Originally Posted by Tri Slow Poke
    Is it really the too-short headtube that you dislike, or the too-long top tube relative to the size?
    Just sayin', bike fit is a matter of proportion more than absolute size, since there are a range available (unless you are already on their largest / smallest size.)
    It might be worthwhile to pay the $100 or so for a professional fit. You'll then be able to find bikes that fit properly underneath you, or know that there's custom in your future.
    If you truly aren't concerned about price, the king of long head tubes is Serotta.
    A good habit is as hard to break as a bad one..
    Jul 2006
    Quote Originally Posted by Len J
    Price range?
    None so far
    New or used?
    No preference yet.
    I ride a size 56 Trek 1000. I don't know what I consider a long head tube. I suppose anything longer than what I have.
    170 lbs.
    Len
    Please see my answers above.
    Jul 2006
    Thanks!
    I'm fairly certain that the top tube is long enough. I've been fitted and it was confirmed. The issue is definately the head tube length.
    Jul 2006
    Hey Len,
    I understand completely what you're saying. I left price out of the equation intentionally so I could get a wide variety of responses.
    Then again, I guess I could just go custom if $7,000 was realistic!!
    Dec 2007
    Simply put (actually, an oversimplification) TT length plays a part in reach and HT length, stack height. I'm assuming your issue is with stack height.
    Missed my point. Trek's have unusually long TOP {edited 'cause I can't think and type} tubes for their vertical size. If you were buying a different brand of bike, when you got an appropriate TT length, the headtube would likely be longer, as you would be on a bike of a larger nominal size.
    Have you really been fitted, or did you spend 15 minutes on a trainer with the salesman that was trying to sell you the bike that he needed to move off the sales floor? There's a world of difference. A quality professional fitting is as much a coaching and education session as it is a measuring exercise.
    I'm not saying that you don't need a taller head tube - you probably do. But there are a bunch of ways to get one, and the various ways introduce different compromises depending on your on-bike goals. Point is, you don't 'just' want a taller head tube. Do you want longer stays with it? Will a taller HT present standover concerns? Do you need it because you are leggy, or because you are relatively inflexible?
    It's a trivial matter to go to the manufacturer's web sites and find HT lengths. It's a different matter entirely to understand what the numbers mean.
    Apr 2006
    I don't get this
    LOL
    Len
    He stated that he had not set a budget, so we offer responses to help and here you come to poo on everyone responding...
    by the way most suggested brands have different levels of trim available at different prices while retaining similar geometries.
    and no I would not.
    I think.........
    that you would be crazy to do anything but custom then.
    You will get:
    - The material you want
    - The ride qualities you want
    - Made to your weight & riding style
    - Designed to your dimensions
    - The aestetics you want
    - Head tube length/Spacers/slope/no-slope
    - Paint/finish
    - The options you want
    - Pump Peg
    - Bottle location
    - Brake types
    - Etc.
    It is basicially a no-comprimise solution.
    Anything else may result in a comprimise somewhere. And at the price of high end "Stock" frames, customs, even from the best of the best, are a more than competitive solution.
    The only thing you give up is some time. Lead times can be anything from a few months to several years. IMO, that is a small price to pay. YMMV
    Len
    Quote Originally Posted by akrafty1
    and no I would not.
    Well.....
    the nuber of alternatives go up the more money you are willing to spend.
    I'm surpised that you think the Madone and/or the Lemond are the pinnacle of choices....especially when you have no idea of his riding style, or any other of his biases other than head tube length....& even that you have no idea of how many spacers he is trying to eliminate.
    I stand by my original post.
    Len
    pegoretti makes long head tubes.
    not cheap (but not Seven or Serotta-expensive, either), but great bikes.
    and you can get a custom for not a whole lot more money.
    wim
    wim is offline
    Feb 2005
    Just a general observation: over the last year or so, more and bikes, including some Treks, have had their head tubes lengthened relative to their nominal size. Up until the 2008 model year, most Trek performance road bikes have had unusually short head tubes relative to their nominal size. So these days, it should be easy for the OP to find a bike his size with a head tube much longer than the one on his '04 Trek.
    Providing you can get your preferred reach without resorting to a stubby stem, it may also be useful to re-examine how much standover clearance and saddle-to-bar drop you want or need. For some riders, choosing the largest acceptable frame makes more sense than choosing the smallest acceptable one.
    Mar 2006
    For some riders, choosing the largest acceptable frame makes more sense than choosing the smallest acceptable one. Word...... This is also a function of the threadless vs threaded design. With 1" threaded, it'd be a simple matter to put in a long shafted Nitto, and raise the bars up a full 2" or more, without dorky riser stems or steering tube extenders. For everyone except racers, where the weight really does matter, I think 1 and 1/8th threadless is a step backwards. Because I'm relatively inflexible, (6 crumbling verterbrae will do that), my next frame is probably gonna have to be 1" threaded.
    Reputation: NealH's Avatar
    May 2004
    Roubaix is a very good choice, as is the Felt equivalent (forget the model number) and, the Trek performance fit. All these offer a taller head tube, and a bike that will likely ride as good or better than any $7K bike. Good bikes don't cost that much . Vanity does.
    now in philadelphia
    Nov 2007
    What about the new Cervelo RS. It's the R3, only with longer HT.
    now in philadelphia
    Nov 2007
    I am personally considering building up an RS for the upcoming race reason.
    Jul 2006
    Quote Originally Posted by danl1
    Missed my point. Trek's have unusually long head tubes for their vertical size. If you were buying a different brand of bike, when you got an appropriate TT length, the headtube would likely be longer, as you would be on a bike of a larger nominal size.
    Hello,
    You bring up excellent points. To answer your first question, I did get a professional fitting, but I already bought the Trek. The fitter didn't recommend a new bike for me. They knew I was broke at the time so they didn't put the sales pitch on me!
    I'm don't think I would have a problem with standover height if I went up a size. However,
    I'd be concerned about the reach. I'm all legs and I'm on the inflexible side.
    Point is, get off the overly long Trek geometry, and you are less likely to have that problem.
    If you wouldn't have problem with standover, my original thought has merit - your problem is less that your HT is too short, but that your TT is too long. Find a bike with shorter geometry and choose a taller size. Can't possibly judge if that's the solution from here of course, but it's as fair a bet as any.
    This is where the professional fitting comes in handy. Get your documents out, look up your calculated frame (horizontal distance from BB to top of HT) and stack (vertical distance of same) and it's easy to find a bike that fits. Unfortunately, the various brands don't have a common measurement standard, so there's going to be a bit of trig involved in evaluating the various brands / models.
    One possibility: Depending on your height, many Italian frames tend to stay relatively shorter (in reach) as they get taller. If you are up in the 58 or larger range, you might find some help there. There are a couple of Merckx models (not all, though) that act this way, too.
    Jan 2007
    Specialized Roubaix... The Roubaix HT is 1.25 inches longer than the Tarmac. I've owned both. Price range from $1,300 to $6,000. Just say'n.
Sea Otter Classic
Contest
