Results 1 to 6 of 6
Thread: Stem Angle
    Apr 2018
    Stem Angle
    Hi..
    I have STEM angle of 7 degrees and I need to replace as its slightly cracked at one of the tightening screw. Can I replace with a 17 Degree stem instead as it would be more comfortable.. Does it require any serious change or adjustment esp in cable lengths for break and gear or any other issue that may arise..?
    Thanks.
    Oct 2013
    Make sure you get your diameters right. If you change the lenght of the stem it will effect that other stuff, but unless you have really tight cables, YGTG.
    BANNED
    Apr 2018
    Thanks..
    Dec 2017
    You can punch in your stem angle and length here to see how it changes your reach.
    Stem Comparison Tool | yojimg.net
    Edit: I dont see my link. Google stem length calculator and its the first hit. Yojimg
    Nov 2002
    Quote Originally Posted by Moonlight View Post
    Hi..
    Thanks.
    Yes, you might find your cables are too short, depending upon how long they are now.
    Reputation: Lombard's Avatar
    May 2014
    That fact is you won't know for sure if your cables will reach until you try it. Going from a 7D to 17D stem isn't that large a difference, so I doubt you will have any cable reach problems unless they are already sized very tight.
  1. new stem angle =longer stem?
    By noavg55 in forum Components, Wrenching
    Last Post: 07-14-2011, 10:37 AM
  2. Seat Angle/Head Angle and reach changes
    By GreenLightGo in forum Cyclocross
    Last Post: 04-15-2011, 10:38 AM
  3. stem angle vs stem length vs bar height geomtery question
    By acid_rider in forum Bikes, Frames and Forks
    Last Post: 05-11-2007, 04:33 AM
  4. HT Angle / ST Angle: Any known mfgs w/ large angle differences?
    By tmanley in forum Bikes, Frames and Forks
    Last Post: 06-07-2006, 06:10 PM
  5. Stem angle, can anyone tell??
    By 10kman in forum General Cycling Discussion
    Last Post: 05-19-2004, 02:40 PM
