Results 1 to 25 of 27
Thread: Tarmac 700 x 25
    Nov 2012
    Tarmac 700 x 25
    Anyone tried running 700 x 25 tires on a Specialized Tarmac?
    Thinking about trying it and just wondered...
    Jan 2013
    It'll work. Will you notice a huge difference in ride quality? Probably not.
    Not sure what model Tarmac you're riding, but they don't impress me as having a particularly refined ride. If the rims on your wheels happen to be either wider or tubeless compatible then you have a little more room to improve ride quality.
    Just a change in the brand of tire might make a noticeable difference. Continentals - nice but kind of hard riding. Michelins Pro 4 or Vittoria Open Corsa - slightly more supple road feel.
    Best bike shop in OC http://aroadbike4u.com
    Bikes I'm currently riding:
    Guru Photon
    Guru Evolo R
    Guru Preamio Ti
    BMC Team Machine
    Giant TCR Advanced
    Pinarello Dogma 65.1
    May 2012
    A friend of mine just put Conti 4000s 25c on his Tarmac SL4 to try out and see if he likes the change. They fit but he said they are "big ugly and heavy" LOL. He is used to lighter 23c. They are on 19mm wide rims. We are riding a century this weekend so it will be a good test.
    Nov 2012
    Riding SL4 Expert. Coming off riding Roubaix and was just interested to get a take on whether anyone had done it.Not looking for a "refined ride" (had the Roubaix for that) just perhaps a wee bit more compliant.
    Too slow to be smart
    Sep 2012
    I have a 25mm Gatorskins on my Tarmac. It rides well and I'm happy with it. I also don't think it looks bad.
    ”Nothing sucks more than that moment during an argument when you realize you’re wrong” - Unknown
    Cycling induced anoesis
    Reputation: PJ352's Avatar
    Dec 2007
    I'm running 25c Conti 4000s's on my '08 Tarmac Comp and think they made a noticeable difference in ride quality. Gotta remember the second half of this equation.. tailor tire pressures to match tire size, rider weight and road conditions.
    Aug 2011
    25C works perfectly fine on my Tarmac SL4.
    Jun 2012
    I'm actually heading in the other direction on my '12 Tarmac...going from a 23mm tire on a 20mm wheel (stocker Specialized turbo tires on a Fulcrum Racing 6 wheel) to a 23mm tire on a 23mm wheel (Conti 4000s on a Rol Race SL wheel)...I'm curious to see what the ride is like.
    It wasn't on the Tarmac but I have a Roubaix that I run 25mm tires on and it rides great (RS10 wheel). Getting the wheel off is kind of a pain though figuring the tire is so much wider than the wheel and it sticks at the brake pads even when they're disengaged...
    Flash! ah–ahhh!
    Reputation: SystemShock's Avatar
    Jun 2008
    Quote Originally Posted by scottma View Post
    Heavy? Wha? Conti lists the GP4000 in 25c at 240 grams. Not really a heavy tire.
    But if you need lighter 25Cs, they exist:
    Michelin Pro4 Service Course in 25c, 215 grams.
    Vittoria Diamante Pro Light 25C, 185 grams(!).
    Vittoria Open Corsa CX 25C, 220 grams.
    Vittoria Chrono, 24C, 175 grams (!).
    Grand Bois 'Blue label', 26C, 222 grams.
    Schwalbe Ultremo ZX 25c, 215 grams.
    Even a lot of the pros are switching to 25mm (tubulars):
    Giro Tech: Rise of the 25mm tire
    Monkhouse: I want to die like my Dad did, peacefully, in his sleep... not screaming in terror like his passengers.
    SystemShock: About Faux News/the Right-Wing Bubble™ – the first thing a cult does is claim that everyone else is lying to you.
    Kitty:
    ROMNEY LANDSLIDE! Man its going to be fun in PO after Election Day
    Platypius:
    I'd rather fellate a syphilitic goat than own a Cervelo.
    Seamus: Saw Bjork poop onstage back in the day. It blew my teenage mind.
    Nov 2012
    Quote Originally Posted by PJ352 View Post
    I'm 175Lbs and ran at 100-105psi on the Roubaix. Didn't like running softer. It always felt a bit sluggish.
    Dec 2007
    Quote Originally Posted by Caneray View Post
    More importantly, running pressures too low runs the risk of pinch flats/ too high actually increases resistance, thus my comment to tailor PSI's based on pertinent factors. Takes some experimenting to find the best compromise.
    FWIW, assuming you're running 25c's on your Roubaix, this Michelin chart says you're pretty much spot on with your current pressures. I'd do similar on your Tarmac.
    Michelin Bicycle USA - A better way forward®
    I think their explanation of the importance of air pressure sums it up.
    Nov 2012
    Had not seen that chart. thanks for the link
    Reputation: looigi's Avatar
    Nov 2010
    That Michelin chart is old-school and CYA. Most recommend lower pressure nowadays.
    I'll just mention that rims with wider bead spacing makes the tires physically wider and exhibit some characteristics of wider tires. On my 23mm wide HED rims, 23mm tires measure 25mm, and 25mm tires closer to 27.5-28mm wide. You can adjust pressures based on their installed width, lowering it if the tire is wider.
    ... 'cuz that's how I roll.
    Nov 2012
    I am old school
    Anyone with sense understands that these things are just guidelines and generalizations. There are always going to be variables.
    Dec 2007
    Exactly... and the variables are where the tailoring/ experimenting come into play.
    Oct 2005
    2012 SL2 Comp frame - I've been running Conti Force/Attack 24/22, Conti Race 25, Specialized Armadillo 25, and soon will be onto Michelin Pro Race 25's and Gatorskin 23's. The 25's all fit fine and ride a little softer over rougher road surfaces. I'm a fan of 25's for heavier riders like me on real world roads. I feel it takes me a little closer towards the ride of a Roubaix, the frame I wanted but couldn't afford (as Specialized NZ sold the Tarmac Comp frame on it's own, but for Roubaix the only option was the S-works ... but I'm way off topic here)
    Mar 2006
    Quote Originally Posted by aroadbike4u View Post
    T
    Hmmmmm... this baffles me. A Tarmac not having a particularly refined ride? It's not supposed to. A Tarmac is a race bike. That's what it is designed for. If you want refinement, Specialized makes the Roubaix for that. Would you put a softer tuning suspension on a Corvette or a Porsche. High performance does come with some compromises.
    Flash! ah–ahhh!
    Jun 2008
    Quote Originally Posted by terbennett View Post
    Even there, it sort of depends on what kind of race. On a long road race on not-so-great roads, a harsh-riding bike can beat you up. European stage-race racing bikes 'back in the day' often rode pretty nicely, and didn't seem to hold anyone back from being fast.
    I mean, I dunno... I guess we could put a saddle and wheels on an I-beam and crow about how 'efficient' it allegedly is, but I'm not sure a lot of ppl would really want to ride it.
    I know folks who've bought uber-stiff bikes and have found that slowly, they use them less and less, in favor of something that rides better. Don't get me wrong, they still like their 'race' bike, but it somehow winds up not being their 'go-to' everyday ride.
    Perhaps you've seen this too, though I don't know what the roads are like where you are.
    Kitty:
    Platypius:
    Reputation: dcgriz's Avatar
    Feb 2011
    Tarmac 700 x 25
    T
    Refinement as in upright geometry and 220mm head tube?
    May 2012
    T
    Bravo the triumph of marketing. Build a bike that rides like 2x4's bolted together and convince people that a "race bike" is supposed to ride like a chuckwagon.
    Heck of a business model.
    Dec 2007
    Quote Originally Posted by wabasso View Post
    I'm not questioning the influence marketing has on the bike (and most any) industry, but race geo does influence ride quality.
    If you doubt this, equalize tires/ pressures and go ride a race and touring bike back to back on the same roads. A longer wheelbase will serve to soften a ride, while a shorter one stiffens it. Just a variation of the effect trail has on steering/ handling.
    That said, I own two Tarmacs and don't find the ride quality particularly harsh*, but I've been riding long enough to remember Italian race bikes with leather saddles and plastic tape.
    * However, as I mentioned previously, I do tailor PSI's to rider weight, tire size and road conditions. Helps a lot, IMO/ E.
    So. Calif.
    Reputation: tom_h's Avatar
    May 2008
    I've weighed the 23mm = 207 grams and the 25mm = 220 grams.
    13g heavier, BFD.
    So. Calif.
    May 2008
    I have an older Sworks SL2, model year 2009.
    Installed a 25mm Conti GP4000s on rear, to try it. Alloy rim width = 20.5mm (outside-outside @ brake track).
    Side-to-side clearance to chain stays is fine. Clearance to the bottom bracket is tight.
    It is hard to get the wheel forward enough to remove & install it. In fact, I had to substitute a slightly smaller diameter skewer nut on the driveside, because my wheel's original skewer nut was interfering with the Chorus 11 rear derailler's main pivot joint.
    So while I think I'd prefer the 25mm on rear, might revert to 23mm because of this mildly annoying front-rear clearance issue.
    Newer Tarmacs might be slightly different (more clearance). Rim width, rear derailleur design, etc, might also be factors.
    Flash! ah–ahhh!
    Jun 2008
    Quote Originally Posted by tom_h View Post
    It's sad when a bike can't even really take a 25mm tire.
    2mm more clearance is a big problem for the design team? Yeesh.
    Kitty:
    Platypius:
    Jun 2012
    I can't talk of the total ride quality yet as I'm still digesting the differences but having played with a 19'ish mm wheel with a 25mm tire vs a 23mm wheel and a 23mm tire, I can say that so far, the fit on my Tarmac is better with the wider wheel vs the wider tire. I can't help but think the performance will be better too.
    I guess I look to,my days as a hard car car guy and my track driving knowledge. If you look at modern "performance" wheel/tire setups vs what were offered 20, 30+ years ago, wheel width has grown and now you see thread sections that are in line with wheel width. This removes sidewall flex issues and drastically improves cornering.
    Now, I know that we're talking about bike tires, not cars but I wonder if there's any validity to this in the cycling world. A 25mm tire on a 19mm wheel sticks out quite a bit past the wheel width, I can't help that this would make for less performance overall. (But a more forgiving ride)
    Either way...I'm rambling...forgive me.
  1. 2011 Tarmac SL2 vs 2012 Tarmac Comp???
    By JinxyJ08 in forum Bikes, Frames and Forks
    Last Post: 05-09-2012, 06:11 AM
  2. 2010 used Tarmac Comp vs 2011 Tarmac Elite
    By thedemonkiwi in forum Bikes, Frames and Forks
    Last Post: 04-28-2011, 10:33 AM
  3. Replies: 4
    Last Post: 11-05-2009, 10:53 PM
  4. 2006 Sworks Tarmac vs. 2007 Pro Tarmac
    By cooltool in forum Specialized
    Last Post: 05-15-2007, 08:01 PM
  5. Replies: 6
    Last Post: 07-08-2006, 09:45 AM
Sea Otter Classic
Contest
