Page 6 of 6 FirstFirst ... 456
Results 126 to 133 of 133
  1. #126
    Reputation: velodog's Avatar
    Sep 2007
    You have just proven my point I try to make to those who may be "loving their bike to death". Experts here disagree, but I can't imagine "rinsing" a bike as with a garden hose, is very good for it. You are taking that sweaty bar tape and turning it into soaking wet bar tape with salty sweat mixed in that will take even longer to dry than if you just put the bike away as-is. A better idea would be to pad dry with a dry cloth as best you can.
    I'll wipe it down with a damp rag after a sweaty ride and hose it down when dirty. My headsets take a beating from my left knee, though only cosmetic. My left foot stays clipped in while stopped, and resting my leg up against the bike puts my sweaty knee up against the headset. Same for the stem, though not as much as there is only minor contact to stem.
    Just honest wear that comes from use. I've got bikes that I've had 30yrs that haven't succumbed to rust yet.
    Too old to ride plastic
  2. #127
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by charlitin View Post
    Well my friend. They call me sweaty! Multiply whatever you think you sweat x10 and then add some more. While I ride I drip down when I move my head. My headsets drip rust after a ride and I have to continue spraying them with lithium grease after each ride. They last me about a year before they get loose and need replacement.
    So no steel for me since that was one of my mayor concerns. RUST! And I live by the ocean and.....
    Ahhhh, you live by the ocean in a hot, humid climate. Salt spray and humidity are probably just as much to blame as anything.
    Sweat pours down from my head too unless I wear a skull cap. Do you wear one? They work:
    https://tinyurl.com/yabg7jze
    -- Warren Buffett
  3. #128
    Quote Originally Posted by DrSmile View Post
    I have rusted through 2 steel frames (an old Raleigh and a Ritchey). And yes it was sweat, it didn't corrode from the inside. I now have 3 Ti frames, but the problem isn't completely solved with Ti because my sweat corrodes through aluminum too, I have popped several front derailleur clamps because of the corrosion build up between the clamp and the Ti frame. I've also corroded completely through aluminum bars despite rinsing the bar tape once a week, and corroded through the Campy nuts that hold on the levers. And before the bike care arguments begin, I clean my bike after every ride. There must be a certain sweat type that corrodes heavily and I have it, because a lot of my friends pretty much never clean their bikes, sweat a lot, and their steel bikes are just fine.
    Obvious cause: your mother was abducted by aliens and you carry their DNA
  4. #129
    Oct 2011
    My wife bought me a couple. I tried them but all they do is delay the inevitable. After 1 he they are drenched in sweat and dripping profusely. More than without. Whenever I ride during the summer every 2hr ride I get home and I can squeeze my clothing and it will drip. My socks are wet and I can also squeeze them. That is how bad I sweat.
  5. #130
    May 2014
    Yikes! But come to think of it, if I lived in Miami, I would probably sweat that way as well. Not that we don't get plenty of hot, hazy, humid weather in NJ. Though when highs are above 90, I go out early or choose easier routes.
    -- Warren Buffett
  6. #131
    Nov 2010
    Try sweat gutr. Works for some.
  7. #132
    Oct 2011
    Yeah aluminum and ti don't mingle well. They can seize. I bought some antiseize paste for this. An aluminum seat post seized on my carbon frame and now is unmovable. I went a little over 6 months without moving and greasing the seat post and it was hard to get out.
    I don't know my type of sweat but so far titanium is my best bet.
    I spray lithium grease on my head set and let it sit.
  8. #133
    Sep 2007
    Have any of you corrosive sweat types tried automotive paste wax on your bikes? It may not completely solve the issue, but a bi-weekly or monthly waxing should offer a measure of protection.
  1. Replies: 36
    Last Post: 02-15-2016, 09:41 AM
  2. "Do you think this is a f***in' bike trail?" or "I need a new jersey"
    By tom93r1 in forum General Cycling Discussion
    Last Post: 07-18-2013, 08:30 AM
  3. Replies: 23
    Last Post: 04-04-2013, 01:06 PM
  4. Windsor "The Hour", Moto - "Messenger", Mercier - "Kilo". Differences???
    By midlife_xs's in forum Motobecane - Mercier
    Last Post: 11-04-2007, 08:57 AM
