Results 1 to 16 of 16
    Aug 2015
    Ti - Straight gauge v Butted
    Hello all,
    I am considering a new frame to replace the carbon bike. I plan to use the bike for fast club rides, and power based turbo sessions. I have a Seven Axiom S with full fenders which I use in the winter and the bike has performed superbly, and some of the fastest group rides last year were on that bike.
    My question would be about a suitable Ti frame to replace carbon. I like the Axiom S and wondered whether a custom made Axiom S would be a better investment than the more expensive Axiom SL, which has butted tubes. I would also have the same query in respect of the difference between the Moots CR and the RSL, and the Mosaic RT2 and the RT1.
    it seems that the huge price increase is down to the butted v straight gauge tubes. Which is better for a 6-2 tall rider, weighing 180 pounds? CAN THE PRICE HIKE BE JUSTIFIED OR WOULD THE STRAIGHT GAUGE ALTERNATIVES BE JUST AS GOOD WITH A HIGH END FORK AND 44 MM HEADTUBE?
    All feedback gratefully received.
    Regards
    Jamie
    A wheelist
    Reputation: Mike T.'s Avatar
    Five years ago I ordered a custom Ti Kish and I asked Jim what the difference was between his butted and plain gauge tubing frames. His honest answer was "About 4 ounces and $300". Of course he could have gone on for 1/2 an e-mail page about the sublime (and unmeasurable) differences but he didn't. I liked that.
    Mike T's home wheelbuilding site - dedicated to providing Newby wheelbuilder's with motivation, information and resources.
    gazing from the shadows
    Jan 2003
    Quote Originally Posted by Mike T. View Post
    Yep.
    For more detail, if desired, Zinn talked about this question here covering differences in materials: Technical Q&A with Lennard Zinn - Keeping it simple | VeloNews.com See the third Q&A.
    I'm not clear why you want to buy what you already have? Can't you just take the fenders off the S you have and change tires if applicable?
    Anyway, generally speaking it's just weight. But to split hairs there is no better and worse just different. If you're a heavy crit rider straight would be the better choice. If you want as plush as possible butting choices will allow the builder to tune in more of that. But that's only applies at the extremes. For a normal weight weekend warrior looking for a normal bike it just doesn't matter because normal bikes can be achieved with either.
    Ask Seven. I did so I know they'll give you an honest very well informed answer and they won't try to up sell. They'll recommend what they think is the better choice regardless of price.
    Nov 2005
    I've had both. A custom lynskey butted r240 and a straight gauge lynskey peloton . I weigh 185- 195 and the mere mortal rider that I am could not tell the difference at all. If fact, I sold the r240 and bought a used steel volagi viaje I'm using as my winter/threat of rain bike and kept the peloton for summer good weather riding that I really like and thought rode smoother to me.
    pmf
    pmf is online now
    Consider a steel bike.
    Aug 2004
    I had the same question for Jim when I was purchasing a new cross bike from him. I went with straight gauge.
    My Bikes
    "It's supposed to be hard...The hard is what makes it great."
    Dec 2009
    Whats wrong with the carbon bike?
    Jan 2009
    Steve Potts doesn't do butted. Says there are very very few benefits if any for Ti
    Reputation: Henry Chinaski's Avatar
    Quote Originally Posted by JAM1E View Post
    There is a pretty big difference between those two frames and it's not just butted tubing. If you are comparing apples to apples with the same geo and basic tubing shapes butted will just make the frame a tad lighter. I'd figure out what you want the bike to ride like and what you want to spend and go from there.
    Apr 2013
    a couple ounces and some stiffness. Titanium can produce a really nice frame. Not necessarily superior to Carbon but does potentially result in some really interesting ride qualities.
    your god hates me
    Reputation: Bob Ross's Avatar
    Apr 2006
    Tom Kellogg has a similarly straight-forward description of the difference between straight and butted tubes somewhere on the Spectrum website, essentially saying that there is no perceptible difference in ride quality...the butted frame will simply be lighter.
    And more expensive.
    Oct 2002
    Carl Strong, same thoughts as well. I wasn't at the cutting end of peletons so went with straight tubes, if the ounces mattered I'd give up chocolate, much cheaper.
    Apr 2013
    Seven cycles claims a 7/10th of a pound weight reduction from going from straight tubing to an ultra-butted frame.
    Straight-tubing 3.3 pounds
    Double butted 3.1 pounds
    Ultra-butted 2.6 pounds
    Once I see a metal frame approaching 2.2 pounds it's getting very near carbon territory. Man carbon frames still come in at 950-1050 grams which is about two pounds. At that point the choice is not about weight but about how the various frames feel and respond. That bottle of water on the bike filled is about two pounds, dwarfing that 0.4 pound differential
    https://www.sevencycles.com/bikes.php
    Dec 2010
    Quote Originally Posted by Trek_5200 View Post
    Frame material alone has no bearing on ride quality.
    Mar 2017
    Quote Originally Posted by Hiro11 View Post
    It isn't the most important factor, but frame material most certainly does affect ride quality, especially when you take into consideration the specific compromises that must be built into a frame to compensate for the particular properties of that frame material.
  1. Straight or butted aero spokes for 200lb rider
    By sandwichnp in forum Wheels and Tires
    Last Post: 04-02-2015, 06:43 AM
  2. straight guage to dbl butted weight savings
    By J24 in forum Wheels and Tires
    Last Post: 08-14-2010, 05:49 PM
  3. Straight Gauge Ti
    By ghostzapper2007 in forum Bikes, Frames and Forks
    Last Post: 06-12-2007, 06:05 PM
  4. Butted versus straight gauge titanium tubing
    By tigoat in forum Bikes, Frames and Forks
    Last Post: 06-29-2006, 05:49 AM
  5. 32 straight vs. 36 butted spoke DRAG?
    By ispoke in forum Wheels and Tires
    Last Post: 07-29-2005, 12:52 PM
