Results 1 to 2 of 2
    Reputation: csh8428's Avatar
    Aug 2007
    Tommaso Aggraziato same as Scattante CFR?
    I've been looking for a new bike and 2 of my choices are the
    The Scattante CFR(http://www.performancebike.com/shop/...tegory_ID=3040) and the Tommaso Aggraziato(http://www.rscycle.com/s.nl/it.A/id....&category=-112
    ). They look to be the exact same frame.
    The geometry measurements look slightly different though.
    Are these the same frames? If not, are they from the same OEM?
    Thanx,
    Craig
    Fini les ecrase-"manets"!
    Reputation: bikeboy389's Avatar
    May 2004
    Quote Originally Posted by csh8428
    Thanx,
    Craig
    I don't know where they come from, but they are plainly NOT the same frame. Look at the seat stays on the Tommasso--they're curved. The Scattante ones are straight. Also, the seat tube contouring is different. The notch in the Scattante is near the top, and the Tommasso is lower, allowing a shorter wheelbase. It took about 10 seconds to spot these two differences. I'm sure there are more.
    But basically, if the geometry is different, and you're talking about the same size bike, then the frames can't be exactly the same.
    They may still have come out of the same factory, but they're not the same.
    "jazz gives you large testicles"--aliensporebomb
Sea Otter Classic
Contest
