Results 1 to 6 of 6
    Aug 2016
    Trek Tire Clearance
    Hey Everyone,
    So I had been wondering about tire clearance on a Trek Domane and what it could fit. A trek rep was in the store when this was being discussed and mentioned that all Trek bikes are designed to have at minimum a 6mm tire clearance on all non-moving parts of the bike. With this in mind I looked at about 3-4 domanes (including my own at home) and there is more like 4-5mm in some sections.
    So a random question, but if trek "designs" their bikes with a minimum of 6mm, why does it seem less on Trek bikes out in the wild? Maybe they don't consider which tires are being used?
    Quote Originally Posted by ejewels View Post
    Hey Everyone,
    The rep is full of crap or you misinterpreted. Bikes are designed with a max tire clearance in mind. Designing around a minimum has no logic at all. It might make a little sense in the context of discussing wind tunnel testing but otherwise just ignore what you heard.
    Aug 2016
    So then if there is less than 6mm somewhere, its ok? This was a previous CS rep from Trek and even said he wasn't too keen on the details, just that the magic number was 6mm in terms of a bikes design to allow for.
    You'll have to decide for yourself how close you're willing to push it.
    Aug 2016
    To clarify a little, the rep said there are bike safety guidelines, and that Trek tries to make sure there is a minimum of 6mm on any non moving parts of the bike of tire clearance. I think its a safety thing?
    Nov 2015
    I suppose it depends how much your wheels/frame flex and how much crap you pick up on your tires while riding. I have around 3-4mm on my road bike (non-Trek, but brand is sort of irrelevant), and it's never been an issue.
    As far as the Domane is concerned, it will fit at least a 28. The direct mount brakes really help with clearance. If you're go with discs, I'd assume that would open it up even more. This is apparently a 28 on a rim bike: http://trek.scene7.com/is/image/Trek..._5_Domane_SL_6
  1. Trek ALR 5 Max tire clearance is.....
    By acckids in forum Trek
    Last Post: 01-22-2016, 07:43 PM
  2. 25c tire clearance
    By de.abeja in forum Bikes, Frames and Forks
    Last Post: 05-12-2009, 01:59 AM
  3. 08 Trek 1.2 Tire Clearance
    By ntekrony in forum Trek
    Last Post: 06-12-2008, 03:16 PM
  4. Tire Clearance on Trek 1500?
    By Onepivot in forum Wheels and Tires
    Last Post: 10-24-2007, 11:46 AM
  5. Tire clearance (Will Cross Tire Fit?)
    By BlueMasi1 in forum Bikes, Frames and Forks
    Last Post: 10-03-2006, 03:44 PM
