Results 1 to 15 of 15
    Dec 2011
    True advantage of lower seatstays ?
    So what is the deal about it ( BMC,2018 Tarmac ) ? Do they make the bike stiffer or just more comfortable ? I still donít get it...
    Happily absent RBR Member
    Reputation: Kontact's Avatar
    Apr 2011
    It makes the bike look different.
    If all bikes were made of the exact same tubing we could talk about what lowering the stays might do to the ride. But with carbon bikes you can make up for just about any shape by altering the layup.
    Forever a Student
    Mar 2014
    It's about aerodynamics. Could also play a part in some comfort, but it came about due to aerodynamics. Most every TT bike has that design now and they were the first category to really push into it.
    I don't think stiffness has anything at all to do with it. And comfort is very minor if anything. Makes fitting fenders like the Crud MK3 a real pain.
    use a torque wrench
    Apr 2011
    This bike was neither comfortable nor aero:
    Forever a Student
    Mar 2014
    Quote Originally Posted by Kontact View Post
    The question is what's the true advantage of lower seat stays.
    The answer is aerodynamics.
    You may think they're only there to look different, it seems that's what you're saying. But my answer is correct.
    use a torque wrench
    Apr 2011
    I'm saying that there are any number of reasons that a bike might be designed with lower seat stays, and only some of them are for aerodynamics - if the frame actually ends up being any more aero at all. The rest are largely aesthetic.
    Reputation: Drone 5200's Avatar
    Mar 2003
    I donít see much or any ďtrueĒ advantage. But like everything else if not done right it can look really ugly...
    https://youtu.be/ttDAm52pUCc
    Feb 2002
    Quote Originally Posted by Devastazione View Post
    It's a clear, visible indication that the bike was built with PFM (pure effing magic) technology. Otherwise, how would you know?
    Aug 2017
    1. Aero
    2. Smaller triangles are technically stiffer
    3. To be different (biggest reason imo)
    Quote Originally Posted by Drone 5200 View Post
    That's a CX bike and they have done it because that shape is more comfortable when carrying the bike over one's shoulder. It's not ugly, it's just function over form.
    I always assumed it was for weightweenieism. you said "low" but some would say "short" and naturally less length means less weight.
    What's the advantage of higher ones? Do you 'get' that? I'm not really asking, just trying to make the point it doesn't matter to who cares.
    JSR
    JSR is offline
    Feb 2006
    The Specialized Roubaix seat stays are short and offset from the junction with the top tube. They claim to have a stiff rear triangle with a compliant seat tube/post setup. Itís pretty nifty, IMO.
    Dec 2011
    Another question : some guy on another forum said they supposedly make the bike bad at climbing.....say what ????
    Reputation: oldcannondale's Avatar
    Jul 2011
    Exactly so, as for Aero's, the Head Tube/Forks "cleave" the high pressure buildup, along with the handlebars and your body, once the leading edge "penetrates", the rest follows along in lower pressure "dirty air"..
    so theoretically lower stays present less surface area due to a lower angle of attack, and the fact that shorter stays present less "wetted area".
    of course the draggiest thing on your bike is your own clothing and body, and helmets can be particularly draggy as well.
    How much this all matters depends of course on your speed, drag rising "exponentially" as speed increases..
    So in the grand scheme of things, seat stays are rather inconsequential, but the aesthetics and product "branding", now that's what really sells bicycles..
    I'm still rather "enamored" of the "hourglass stays" on my old Cannondale R700, Heh?
    and the best of all, looking down at that "Made in USA" sticker right behind the head tube??
    Jul 2011
    Cool
    Quote Originally Posted by K4m1k4z3 View Post
    1. Aero
    While we likely will all agree with 1 and 3,,,, technically larger triangles, lugs, tubes and drop-outs being the same are more stiff, and resist the bending moment of vertical forces acting on the rear tire with more authority...
    and that top tube, seat tube juncture, while allowing the seat tube more "compliance", is also lacking in the "style" department, but that of course in not measurable and is subjective...
    Jul 2011
    Quote Originally Posted by JSR View Post
    The relatively lower, up seat stay attach point on the seat tube, should technically allow the rear tire greater vertical and lateral compliance, in addition to allowing greater compliance in the upper seat tube. I do like the appearance of Specialized frame, and I should say that I found BMCs lower attach point of seat stays to be very attractive, or maybe just "different"?
  1. Lower Lower Back Pain
    By MWPDX in forum The Lounge
    Last Post: 03-06-2009, 08:32 AM
  2. lower end cross bikes with carbon seatstays
    By twest820 in forum Cyclocross
    Last Post: 09-09-2008, 12:03 PM
  3. Carbon Seatstays
    By bigriderblack in forum Components, Wrenching
    Last Post: 09-01-2008, 05:10 PM
  4. carbon seatstays impact
    By uspsjj9wldcat in forum Components, Wrenching
    Last Post: 04-18-2004, 05:42 AM
  5. Litespeed Choice - better frame, lower wheels or lower frame better wheels
    By Cool Roadie nom de Plume in forum Bikes, Frames and Forks
    Last Post: 04-15-2004, 10:29 PM
