Results 1 to 6 of 6
    Find Life to Live Life
    Jul 2004
    Types of steel: lugged, double butted, etc??
    What are the differences between all these types? My bike has Columbus Thron double butted chromoly steel tubing. What does that mean?
    Old and Fixed, Moderator
    Jan 2002
    Quote Originally Posted by UCLA_MCDbio
    http://www.m-gineering.nl/buizeng.htm
    Dave Hickey/ Fort Worth
    Jul 2004
    Good
    That means it's made of pretty good steel tubes. Double butted means the tubes are thicker at the ends where they are joined so they can be light an strong.
    Aug 2003
    Thron was Columbus's lowest-cost tubeset that had all of the "good" qualities for bicycle tubing:
    Chromoly: Steel alloy using small amounts of chromium and molybdenum. Chromoly steel probably has the best strength / weight / cost relationship of any material for bicycle frames. Not the "best", mind you, just the most even distribution of compromises. All steel alloys are about equally stiff and weigh about the same, by volume. They vary in strength quite a bit. Stonger metal can be used to build a lighter bike, by using less of it.
    Seamless: Formed by drawing "cold" steel over a mandrel. This imparts a grain to the metal, and creates a stronger tube than seamed tubing, which is rolled from sheet steel, welded along the edge, and then processed to remove the seam.
    Double-butted: Thicker on the ends than in the middle. Typical wall thicknesses for bicycle tubing vary from 1.0 - 0.6 in the butted sections, and 0.8 - 0.4 in the center sections. Thron would be at the upper end, probably .9/.7/.9 and maybe 1.0/.8/1.0 in larger frames.
    Lugged refers to one of the three common ways to attach steel tube together to make a bicycle. In a lugged frame, the tubes are fitted into steel "sockets", called lugs. The joint is brazed togehter: heated with a torch and silver or brass solder is wicked into the gap between the tube and the lug. "Fillet brazed" frames are brass brazed without lugs. The builder builds up a "fillet" (fill-it), a little curve of molten brass between the tubes. TIG-welded frames are made by butting the tube directly up on another and passing an electric current through them. This melts the two tubes together. Any method can build a good or a terrible frame, though the different methods have different advantages (and disadvantages).
    --Shannon
    Reputation: Nessism's Avatar
    Thorn info
    Quote Originally Posted by tube_ee
    --Shannon
    Shannon, your post is very good overall but I can add some further info regarding the tubing.
    Thorn tubing is "over size" which means it has a 1-1/8" top and seat tube, and a 1-1/4" down tube. The down tube is .8/.5/.8 and the top tube is .8/.6/.8. These wall thicknesses are medium-thick by modern standards but not overly so.
    While Thorn may be on the thicker side compared to some other tube sets, but this is not necessarly a bad thing depending on the purpose of the frame. For example, if stiffness is desired thicker tubes are needed.
    Good luck.
    Ed
    Thickness
    Quote Originally Posted by Nessism
    Good luck.
    Ed
    Or use a larger diameter and draw it thinner.Thron is just plain cromo., avable is both standard and oversize.
  1. Replies: 38
    Last Post: 09-09-2004, 07:08 PM
  2. Replies: 14
    Last Post: 08-13-2004, 06:54 PM
  3. Manufacturers of lugged Italian steel frames
    By BNA_roadie in forum General Cycling Discussion
    Last Post: 08-05-2004, 02:43 PM
  4. Lugged steel top tube ding
    By rroselli in forum Fixed/Single Speed
    Last Post: 07-09-2004, 11:21 PM
  5. Did somebody say lugged Italian steel?
    By EvilGilligan in forum General Cycling Discussion
    Last Post: 05-17-2004, 07:10 AM
