Results 1 to 2 of 2
    Jul 2016
    Upgrading from a cross bike. Look at endurance bikes?
    Been riding for a year on an old Cross bike. Weighs in at 25lbs. I think it's time to upgrade to a real road bike.
    I'm looking at endurance frames for comfort. Some of the roads I ride are quite cracked so I'm looking at a Trek Domane.
    Climbing is my nemesis. For example a 4% grade over 1.8 miles my average speed is 10mph. On strava it seems like other guys are pushing 14mph.
    My budget is $2k though the lower the better as I'd like to buy a nicer wheelset. I'm not opposed to used either. I think I want to stick with disc because you can fit larger tires. I currently ride 37-622 which is 35c tires. That's about as small as I want to go. 23 and even 28c tires seem to produce a jarring ride.
    Or perhaps I should upgrade my cross bike instead to make it faster? I probably won't get the comfort but if I can hang with other riders and not get smoked then it might make the ride more enjoyable. I'm sure I could probably drop a pound by going with a better wheelset. Current ones use a disc hub with a rim brake rim and some City Ride 2 tires.
    Feb 2002
    Quote Originally Posted by mrfat View Post
    If you could shave 10 lbs off the bike, your climbing speed would increase about 1 mph. If you want to get to 14 mph, you need a bigger motor or to lose 40 lbs from the bike and body while keeping power output constant.
    It is possible to use brakes other than discs that allow wide tires.
  1. Replies: 3
    Last Post: 02-09-2016, 02:33 PM
  2. Endurance road bike or cross bike for winter bike
    By Sbccbs in forum Bikes, Frames and Forks
    Last Post: 10-23-2015, 01:42 AM
  3. Any other endurance races like Iron Cross out there?
    By fueledbymetal in forum Cyclocross
    Last Post: 09-11-2008, 06:18 PM
  4. endurance or cross
    By RCKelly in forum Bikes, Frames and Forks
    Last Post: 02-11-2008, 08:16 AM
