Results 1 to 18 of 18
    Jan 2018
    Vintage Cannondale?
    Just got my hands on a blue vintage Cannondale road bike...serial number is CC04607....anybody know if its worth hanging on to?...it has suntour cyclone ders. ans a sugino crank and dia-compe 400 brakes ...its a bit scratched up but overall good shape.. aluminum frame? Anybody have any idea about this bike?.
    Reputation: Drone 5200's Avatar
    Mar 2003
    Sorry, I dont know much about the bike, but to answer your question: Yes, of course, it's worth holding on to. Unless there is rust, or its damaged, it should be enjoyed!
    Jan 2010
    No other markings?
    A picture would help. I can look in the old catalogs.
    There's sometimes a buggy.
    One.
    Russian Troll Farmer
    Sep 2016
    It's aluminum. Aluminum doesn't rust.
    With those components (and that serial #), it's from 1985.
    http://vintagecannondale.com/year/1985/1985.pdf
    "L'enfer, c'est les autres"
    a real member's member
    Jul 2016
    Quote Originally Posted by Mikethegreek View Post
    it has suntour cyclone, sugino crank, and dia-compe 400 brakes.
    good stuff. cyclone was the top of the suntour line.
    drive-side pics always help.
    Jan 2018
    Havent figured out how to upload pics ...help...will post.some soon..is it decent frame ...never owned an aluminum bike before
    Nov 2010
    Quote Originally Posted by blackfrancois View Post
    Believe cyclone was the ultegra or 105 of the sun tour line . Still good stuff.
    Is the frame designed for 6 speed? Steel fork? If so, sounds like 85 is about right. I believe I owned that model. It was the first “racing bike”sold by cannondale
    Jan 2018
    It is an original 6 speed setup...
    I was hoping to put upgrade the drivetrain with an 8 speed freewheel....is it possible?...also would.like to switch to brifters. Any ideas?
    Reputation: BCSaltchucker's Avatar
    Jul 2011
    I think if you want to do resto-mod to brifters, then get some newer wheels with cassette-hubs. but I see there are 8 speed shimano compatible screw on freewheels. might need to monkey around with the axle though
    Faith is pretending to know things you don't know
    Reputation: Lombard's Avatar
    May 2014
    Aluminum doesn't rust per se, but it does oxidize and parts do seize.
    Interesting vintage catalog. I especially found interesting Cannondale's claim that aluminum dampens road vibrations better than steel. This is the opposite of what we are generally told today.
    1) Go Advanced.
    2) Scroll down and click "upload photos.
    3) In new window, click "add files".
    4) Click "choose file" and find your photo".
    5) Click "upload file".
    6) Click "done".
    7) Submit reply.
    That's it!
    Converting a 6-speed to an 8-speed may not be possible unless your rear axle width is 130mm. Some older frames are narrower.
    Br........um.....STI shifters are nice. Please don't use the B-word here or CXWrench will flog you with a used br........um.......I mean shifter cable.
    -- Warren Buffett
    Jan 2010
    For me it's:
    Hit "reply"
    In the reply window at the top is a line of icons. Hover over and you see that one is "insert image"
    The image box then gives you the choice of linking to an image address (copy and paste) or uploading an image file from your computer.
    One.
    pmf
    pmf is offline
    I had a Cannondale way back ... it was a 3.0 frame, succeeded by the 2.8 frame and then the CAD series started. It had 7-speed components. After several years, I put an Ultegra 8-speed STI group on it that was taken off a bike I was upgrading. The rear spacing wasn't quite wide enough, so I had to spread it apart a but with my hands to get the rear wheel to fit. The wheel would never center, but it rode OK until one of the drop outs cracked. Frankly, I was kind of glad the bike was kaput -- it was the most uncomfortable bike I've ever owned. I haven't owned an aluminum bike since.
    If it were me, I'd let the thing lie where you found it. Or maybe sell it to some sucker on Craigslist. Maybe ride it as is, but definitely don't put any money into it.
    Jan 2010
    I was going to say something along the same lines. Really not worth putting money into except just to get riding. There's going to be many many nice frames from the '90's and later that are worth an upgrade more than this.
    One.
    hfc
    hfc is offline
    Doesn't like subtitles
    Reputation: hfc's Avatar
    Jan 2003
    The older Cannondales have a good reputation as racers; very stiff, corner well, crit racer stuff. With that in mind, might not be a comfy ride all day kind of bike. In general it's not a problem putting more modern components on an older 126 mm spaced frame, but an aluminum one may be problematic as the rear triangle doesn't have as much flex to it as steel and you might damage the frame.
    Sep 2016
    That frame is certainly a 126mm spacing. Being aluminum, you can NOT increase it, so the best thing you can do is:
    1) convert to 7 speed, using 8 speed shifters or BRIFTERS.
    2) Try some 8-of-a 9(or 10)-speed setup, playing around a lot with axle spacers and lengths, wheel dish, etc. It's probably possible...
    FWIW, 8 sp freeWHEELS are pretty rare, incompatible with 126mm spacing, and really terrible. FreeHUBS have been the state-of-the-art for about 30 years now. So much so that most new freewheels are now just junky stuff for department store garbage bikes.
    Aug 2017
    It's only 4mm. Cold set it and go ride. Old Whales are jackhammers btw...
    Sent from my ONEPLUS A5010 using Tapatalk
    Sep 2016
    Quote Originally Posted by Hellgate64 View Post
    Aluminum can NOT be 'cold set'. Any wrench would know this.
    wim
    wim is offline
    Feb 2005
    True. Don't do it.
    I raced an '87 3.0 Criterium with that nasty unforgiving steel fork. Fine race bike, but not a good bike for long recreational rides. Check for corrosion around the plastic top tube cable guides--paint bubbles are your first indication.
  1. Replies: 8
    Last Post: 06-16-2015, 06:44 PM
  2. Pristine Vintage 1987 Cannondale SR500 Value
    By Esplanade in forum Cannondale
    Last Post: 11-15-2012, 04:03 AM
  3. Wheelset advice for vintage Cannondale
    By rivrwing in forum Wheels and Tires
    Last Post: 03-06-2011, 04:19 PM
  4. Wheel/Rim Info Needed For Vintage Cannondale R700
    By chris1pat in forum Retro-Classic
    Last Post: 08-06-2010, 04:52 AM
  5. Vintage Cannondale - What to do
    By LoupyLouie in forum Retro-Classic
    Last Post: 05-23-2008, 08:04 AM
