Results 1 to 25 of 38
    tthome
    May 2008
    Wife is 4 ft 10 inches - need some frame / bike advice
    My wife is 4' - 10" tall. I've purchased here the smallest road bike I could find that had 700c wheels simply because of the fact she might need to borrow a tube or something while riding with other women. The XS is a size 44cm Fuji aluminum frame.
    I have the seatpost slammed all the way down and have replaced the original stem with a 30mm stubbie.
    I'm curious if they make an even smaller frame anywhere that might be a tick smaller than a 44cm while still using a 700c wheel.
    I'd like to get her on carbon however right now I'm simply trying to get her something that fits her a bit better. She's already stretched out a bit. I'm very close to changing out her rounded drop handlebars to straight so she doesn't feel she has to lean over on the hoods.
    Any advice would be appreciated.
    Please support and visit my cycling website BunchSprint. Cycling news, reviews and tips.
    http://www.bunchsprint.com/wp-conten...ple_avatar.png
    Oct 2013
    Why are you so hung up on 700 wheels?
    BANNED
    tthome
    May 2008
    Trying to keep her with 700c in the event she runs into problem on a group ride with her tubes/tires and needs to borrow something from other riders. She could easily run 650 tires however she'd need to ensure she had everything (and possibly extra) just in case of double flats/cut tires/etc. Not hung up on 700c, simply trying to ensure that if she's got to "borrow" something from other riders or the SAG vehicles her bike is more common than not. It's not about going to a smaller wheel, I'm simply asking if there are smaller frames than what I've been able to locate that have 700c wheels.
    Not sure if it would be 'necessary' but going custom would obviously solve the fit issue. The problem there is wait time. Budget may not be as much a problem as you may expect. There are some reasonable options.
    Oct 2013
    I feel that you are making big compromises just so she can borrow a tube.
    I would rather be stuck on the road thumbing it home than have a major off due to unforseen toe overlap disaster. There is no way your going to get around toe overlap on a small frame unless you go to a touring bike or such.
    How hard is it to put 2 tubes & patch kit on a bike?
    BANNED
    tthome
    May 2008
    It's not, I'm simply asking if anyone knows of any manufacturers that might make a smaller frame than a 44cm the accommodates 700c wheels. Serves other purposes too such as me giving her my lighter carbon wheelset, tires and other stuff that I too use.
    Dec 2014
    Well.. the true cyclist response would be.. get a taller wife
    Quote Originally Posted by tthome View Post
    I am thinking that you are at the design limit and it simply isn't possible to go smaller with 700c
    Happily absent RBR Member
    Reputation: Kontact's Avatar
    Apr 2011
    The only way to make truly small 700c wheeled bike is to use an extremely relaxed head tube with a correspondingly super high rake fork. It just isn't going to work. Stop punishing her for being short and get her a bike that fits.
    Tubes and patches are small, as are cell phones. Put slime in the tubes.
    Forever a Student
    Mar 2014
    700c is a big mistake.
    She'll never have to borrow a wheel and can carry her own tubes.
    And let's be honest here... I've done over 10,000 miles since my last flat, if you have the right tires/pressures/roads it really isn't a problem.
    Canyon makes a nice women's 650b carbon ultimate wmn. I'd buy her that.
    use a torque wrench
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    Quote Originally Posted by ljvb View Post
    WONG. The True cyclist response would be N+1
    Agree. Its not like people are riding around with a spare wheel to give her. At 4'10" if she breaks down you can just toss her in a jersey pocket
    'brifter' is a lame word.
    My ex had Ron Cooper build her a custom. She was also 4'10". He managed to get her on a 700c bike for the same reasons you're thinking about. She raced a lot and did a bunch of events w/ neutral support. I don't remember the specifics of the geometry but I think she had a touch of toe overlap but dealt w/ it just fine. These days I've probably recommend 650b wheels and a tire like the Schwalbe Pro One.
    I work for some bike racers
    and a bunch of skateboards
    Oct 2013
    He probably wants new wheels and wants to move his to hers'!
    A pro has a reason for 700's and the skills to handle whatever toe overlap/handling that includes. I have seen people have problems, I even have hit the wheel but I saved it.
    I like going around corners and I think a small 650 would handle a lot better than a super small 700.
    BANNED
    Russian Troll Farmer
    Sep 2016
    Dood, you can always fold a too-large tube over. I was talking with Georgina Terry once, somebody made this comment, and she SHOWED us how well the folded-tube worked on her 24" front. You are getting concerned about a non-issue.
    FWIW, frames for very short people NEVER work well with 700 wheels-that's why Terry makes most of her bikes with 24" fronts and 700c rears. That way the geometry isn't screwy.
    "L'enfer, c'est les autres"
    Apr 2013
    rather than compromise the bike fit, my suggestion would be to contact a seven cycles and explore a custom fit. nothing worse than riding a bike that's not a good fit. been there and done that and it compromises the ride experience
    Dec 2006
    Add my name to the camp of "you can't get a properly fitting 700c wheeled bike for your short wife".
    And people; the proper sized road bike for the wife has 650c wheels, not 650b. The difference is a rim bead seat of 571mm vs. 584mm for the 650b.
    Keep a stock of tires and tubes at home so she's never waiting for special orders to get her back on the road, and be a kind hubby and always make sure her spares are ready to go in her saddle bag.
    Apr 2011
    At my last shop the owner designed a Seven for a women who is 5'2" using Seven's fork that goes out to 58mm of rake. I forget how slack the headtube was, but I'm thinking that 69° and a trail of 68mm is about as far as you'd want to push it. With a 69 HTA and 73 STA, you can get down to an honest 49cm TT (which would look like 48cm with a 74 HTA). coupled with a 80mm stem, very short HT and a sloped TT it could work. Rear brakes start getting in the way with very low rear stays, though.
    Quote Originally Posted by Peter P. View Post
    You can easily use 650b wheels as well. Depends where you're going to be riding and what kind/size tire you'd like. Yes, the classic 'small' road size wheel is 650c but that might be changing.
    Reputation: velodog's Avatar
    Sep 2007
    I'm a fan of 650b but they are hard to find much smaller than 38mm. Grand Bois can be had at 32mm and I've heard that Michelin has\had a 32, but they're not always available.
    But I think that either 650b or c would suit her much more than 700c. Should be faster handling than the larger 700c wheels. And even with larger diameter tires the smaller wheels would be lighter, if that's a concern.
    The smaller wheels would allow a bike design that works, not a hack to try and make it handle like a conventional bike.
    Too old to ride plastic
    Reputation: Lombard's Avatar
    May 2014
    I don't think toe overlap is the major issue with shorter riders. I'm 5' 10", take a 56 frame and have toe overlap on both my road bikes with my size 11 1/2 feet.
    The main issue is if her saddle is slammed down, she is probably not getting a correct fit.
    650b wheels sound like the only answer here. I don't believe there are adult frames smaller than 44.
    Apr 2013
    i'm 5'5 and ride a 45 cm sloping colnago. it's possible a 41 cm sloping colnago would work.
    Jun 2005
    You can stuff 700c tubes in an emergency in 650b tires. Not pretty but will get you home. I have done it with 26” tires too. 46cm frames usually come with 650b wheels to avoid toe overlapping in front.
    Oct 2013
    I think you are saying y are short?
    BANNED
    Frog Whisperer
    May 2003
    My wife is 5 foot 6 and doesn't ride. I'll trade wives, that would solve both our problems.
    Of course I'm sure...that doesn't mean I'm right.....
    "There's no sense being stupid unless you show it."
    "that was like trying to teach a goldfish how to play basketball over the phone."
  1. Need to Raise Handlebars 4-6 Inches ....
    By vja4Him in forum Components, Wrenching
    Last Post: 07-01-2011, 04:17 PM
  2. weight loss with fixed gear/ need help with gear inches
    By kroettger1 in forum Fixed/Single Speed
    Last Post: 12-22-2006, 09:52 AM
  3. OLN inches toward the door - Bull Riders Rejoice!
    By terry b in forum Pro Cycling - Tour de France
    Last Post: 07-22-2005, 10:32 AM
  4. Gear inches-31.5 to 38. Big difference?
    By upstateSC-rider in forum Components, Wrenching
    Last Post: 04-26-2005, 08:28 AM
  5. Inches is inches... yes or no?
    By Auriaprottu in forum Fixed/Single Speed
    Last Post: 02-19-2004, 04:31 AM
