Results 1 to 18 of 18
    Dec 2005
    11 spd noise (SR) v 10 spd noise (Chorus)
    I have two bikes - one with 2005 Chorus, one with 2011 SR. Rear shifting on both bikes is remarkable: think, shift. Front shifting on the SR is definitely faster. However, when I am riding, the 2005 Chorus is virtually silent while the 2011 SR record is noisy - the noise from the chain going around the cassette.
    Lube helps damp the noise, but I can't reach the level of silence on my SR that I have on my Chorus. Both bikes use 50 x 34. The Chorus has a 25t big cog while the SR has a 27 tooth big cog.
    Has anyone else experienced this?
    Reputation: spade2you's Avatar
    May 2009
    Is your cassette ring tight?
    Big is relative
    Reputation: bigbill's Avatar
    Feb 2005
    What he said, check the cassette. I have 11 speed on two bikes and all I hear is my breathing and the sound of the tires.
    Retired sailor
    Reputation: Pirx's Avatar
    Aug 2009
    Is the SR11 brand-new? In my experience, new cassettes can run a bit on the noisy side. If that's the case, things should quiet down within a few hundred miles. Remember, Campy wears in... Other than that, I'm really happy with Chain-L No.5 for my chain lube. Lasts forever, and makes the drivetrain virtually silent.
    Jan 2002
    I also find the 11s much, much quieter than 10s. I can also verify that Chain-L makes for the quietest drivetrain of any lube I have tried.
    TOM
    USA Cycling Certified Coach
    Cycle University
    www.tomsbicycleblog.blogspot.com
    2014 S-Works Tarmac SL4 Conador Edition Campy Super Record
    2012 S-Works Epic 29er
    2009 Rodriguez Custom Steel Campy Super Record
    Reputation: Fignon's Barber's Avatar
    Mar 2004
    Had same experience, 2005 chorus and then 2010 chorus 11 speed. after about 800 miles or so, the 11 speed overall was quieter and shifted better.
    Dec 2005
    Thanks for all the replies. I guess what you are all saying is the following:
    1. Check the cassette
    2. Lube the chain
    3. Ride more
    Thank you all, much appreicated.
    Feb 2005
    If the groups are on different frames (I assume they are), you might also want to check the derailleur hanger on the noisy one. I have 2005 Chorus and thought it was noisier than it should be. I straightened the hanger (very, very slight adjustment needed), and it ran silent.
    May 2009
    Could be that the wheel is amplifying the sound. I know when I'm using my deep carbon rims, shifting seems louder.
    dropped!
    Reputation: r_mutt's Avatar
    Aug 2007
    i am experiencing the same thing 11 speed is noisy!
    Bianchi-Campagnolo
    Reputation: kbwh's Avatar
    The hollow pin chain (Record/SR) is claimed to be noisier than the solid pin chain.
    Noise could also be a "B" screw issue. Is the top pulley wheel at the correct distance from the cassette?
    dropped!
    Aug 2007
    i am running chorus chains. i think the pin is solid.
    what do you mean by top pulley wheel at the correct distance from the cassette?
    Oct 2009
    I hear noise but just in 12 11 cog
    Nov 2011
    Campagnolo 11 speed tuning problems
    I have also experienced this problem. Further I find they need constant tuning and a good wet lube. After running 10 speed record until late 2008, I distinctly recall getting new SR 11 speed and thinking how noisy and unreliable it was. Agree, front changer a big improvement. With later iterations, it seems the problems have diminished, although would never run with internal cable routing again.
    Jan 2002
    Something is definitely wrong with the setup if you are having noisy 11s problems. I had one of the first 11s (SR) groups in the US when I got my 2009 stuff in late October of 2008. My right shifter had the cable head issue (fixed under warranty) but from the start I was blown away by how silent 11s was compared to anything else, including Campy 10s.
    I also have a 2010 group on another bike. Both run silently and I never have to do anything other than a cable tension adjusmtent 100 miles or so after new cables are installed.
    TOM
    Cycle University
    Bianchi-Campagnolo
    Quote Originally Posted by r_mutt View Post
    Read this and take special note of fig. 11 and 12: http://www.campagnolo.com/repository...leur_01-11.pdf
    Jan 2002
    The B screw is used to adjust the distance from the upper pulley to the chain when it is running on the largest cog. If the pulley is to close to the cog, the pulley will "tick tick" as the chain rotates through. In my experience, this should only occur when the chain is on the largest cog, but I am not sure about that.
    TOM
    Cycle University
    dropped!
    Aug 2007
    just had a go at adjusting this distance to the recommended 7mm. it's quite tough to measure with the chain still on the bike, and although i feel i got pretty close, it's still not a model of quietness that the 10 speed is. the 10 speed chorus on my cx bike is virtually silent.
  1. What is this noise? Help!
    By middcrossrx in forum Components, Wrenching
    Last Post: 05-29-2010, 07:20 PM
  2. Noise
    By ibfeet in forum Wheels and Tires
    Last Post: 10-23-2009, 07:09 AM
  3. Noise
    By Howard3 in forum General Cycling Discussion
    Last Post: 03-26-2008, 09:56 AM
  4. Noise that nobody can tell me what it is...
    By pedaling pyrate in forum Components, Wrenching
    Last Post: 05-18-2005, 09:43 AM
  5. FSA BB noise
    By mellowman in forum Components, Wrenching
    Last Post: 05-16-2004, 09:44 AM
Sea Otter Classic
Contest
