Results 1 to 5 of 5
    Reputation: aussiebullet's Avatar
    Sep 2005
    2007 record r/h shifter lost its click diagnosis?
    My 2007 record r/h shifter has lost its click and l stuggle to get it to shift without over shifting. Up and down shifts are the same no click when shifting, is it terminal or is this a common problem that some new inner bits should solve, it has done approx 25000km l do not think it is all that many for a campy shifter to give up, has anyone had this issue and what parts needed replacing?
    Reputation: skaboo's Avatar
    Apr 2008
    G Spring
    You need your G spring replaced. Check out the Campagnolo threads for do-it-your-self info, or an IBD with a good mechanic can do it.
    .._\___
    ../__|__\_
    (o)--------(o)
    MINI Cooper S
    Sep 2005
    Thanks, so l need a new g-string ah l mean a new g spring right that sounds easy enough,
    much appreciated.
    Reputation: BeeCharmer's Avatar
    Apr 2003
    Check out the youtube vids. First time takes about an hour, but you'll get better.
    http://www.youtube.com/watch?v=2t0ttU_Jm0Y
    cycling as lifestyle
    Reputation: nenad's Avatar
    May 2004
    I, right now, have a similar problem, I can still shift but the lever will occasionally skip a cog when up-shifting. I opened up the lever and, strangely enough, the g springs look good but the g spring carrier/holder cracked. So, I ordered 2 new g springs and a g spring carrier, it cost me $20 with shipping.
    The youtube clip mentioned above will guide you through, it ain't that hard, I've done it before.
