Results 1 to 4 of 4
Thread: 2014 36/52 bcd?
    Jan 2009
    2014 36/52 bcd?
    Does anyone know BCD? Do I have to use proprietary Campy chainrings? Or would TA, SRAM work?
    So. Calif.
    Reputation: tom_h's Avatar
    May 2008
    All recent Campy cranks have been either 135mm or hybrid 110/112mm BCD. I doubt this would change for 2014. Campy's 52-36 uses the compact 110/112 crank.
    Choices are using OEM Campy chainrings, and the only other I'd use is Stronglight Type D, which match Campy's BCD and have similar shift quality.
    TA chainrings have only 1/2 the number of pins & ramps as Campy & Stronglight, so I would not expect TA to shift as fast. For racing or very fast group rides, this is a non-starter for me.
    Note newer Campy chainrings (2011 & up , i think) use a threaded hole, small ring ... therefore requires a male-only chainring bolt, not the usual 2-piece bolts.
    Stronglight still requires traditional 2-piece bolt, a plus in my book, because you can select much more durable steel bolts instead of the flimsy & easy to strip aluminum bolts.
    Jan 2010
    Answer to OP is that it's a proprietary, ie non standard 110 BCD. The rings would have to be "campy compatible" at least.
    There's sometimes a buggy.
    One.
    J24
    J24 is offline
    Oct 2003
    Quote Originally Posted by framesti View Post
    Must be campy compatible: TA, Stonglight, Miche, and Ambrosio make Campy compatible chainrings, there are probably others.
  1. 2014 awol
    By pdainsworth in forum Specialized
    Last Post: 4 Days Ago, 03:02 AM
  2. 2014 Giant
    By vboy19 in forum Giant
    Last Post: 09-08-2013, 12:54 AM
  3. RBR Predictions TdF 2014; post by 2014 Start time
    By PJay in forum Pro Cycling - Race Discussion
    Last Post: 07-21-2013, 10:55 PM
  4. SL5 Will it be there in 2014?
    By Arnoud in forum Specialized
    Last Post: 04-09-2013, 04:59 PM
  5. Sochi 2014
    By bigmig19 in forum The Lounge
    Last Post: 03-04-2010, 04:23 AM
Sea Otter Classic
Contest
