Results 1 to 4 of 4
    cs1
    cs1 is offline
    Reputation: cs1's Avatar
    Sep 2003
    9 sp Ergo Gear Question
    I recently picked up a set of second gen Ergo shifters. They are 9 sp but how can I tell if they're the pre 2000 or later? Are the gears stamped differently?
    1995 Waterford 1200
    1999 Waterford RSE-11
    Plus a host of old bikes too many to list.
    Jan 2010
    I don't know how you can tell the difference. But it does not make a whole lot of difference. I've used the pre 2000 Chorus levers with post 2000 rear derailleur successfully. Shifting was not quite as good. But still OK.
    mtnroadie
    Reputation: mtnroadie's Avatar
    Jul 2010
    I just passed on a set that were on NH CL cheap, they were the 1998 ones pre ergo and not able to be updated to 10 speed. The easiest way to tell is if the shift levers are silver and have holes in them they are 1998.
    Also check out Campy's website they still have all of the spare parts catalogs from that era.
    cs1
    cs1 is offline
    Sep 2003
    Quote Originally Posted by RussellS View Post
    That's the problem I'm having now. It works but not well. At least not what I've come to expect Campy to work like.
    1995 Waterford 1200
  1. 2006 Ergo Lever Question
    By formulacarl in forum Campagnolo
    Last Post: 08-30-2009, 11:54 AM
  2. Sidi Ergo 2 question
    By slimjw in forum General Cycling Discussion
    Last Post: 12-11-2008, 12:47 PM
  3. Sidi Ergo 1 question
    By encomium in forum Components, Wrenching
    Last Post: 06-08-2007, 09:33 AM
  4. Question about brake levers (non ergo)
    By croswell1 in forum Components, Wrenching
    Last Post: 04-26-2005, 06:04 PM
  5. Question about brake levers (non ergo)
    By croswell1 in forum Campagnolo
    Last Post: 04-22-2005, 07:17 PM
Sea Otter Classic
Contest
