Results 1 to 4 of 4
    Reputation: clm2206's Avatar
    Sep 2006
    Is Campy MIrage rear hub 11 sp compatible?
    Hello
    I've found this cheap Campy Mirage rear hub to build a trainer wheel, but it's labeled as a "9 speed hub". I own a Super Record group, so I'm not sure if this hub can fit a new 11 sp Campy cassette. Any ideas before buying this hub?
    Militant commuter
    Reputation: SilverStar's Avatar
    Jan 2008
    As far as I know, yes -- there's no appreciable difference in size between 9/10/11 speed cassettes. That's one of the things Campy got right: no instant obsolescence on their freehub bodies when 11s came out.
    And, this topic was covered recently:
    Campagnolo Record Rear Hub 9/10 - work with 11-speed? While it wasn't Mirage-specific, the same applies to you and your hub.
    "Luminous beings are we...not this crude matter!"
    Sep 2006
    Ok!! Thanks so much.
    Sooper Dooper Moderator!
    Reputation: il sogno's Avatar
    Jul 2002
    I was about to ask the same question. Mine is my old Campy Record hub from 2000. Thanks for the answer and link!
Sea Otter Classic
Contest
