Results 1 to 17 of 17
    Reputation: redmasi's Avatar
    Jul 2010
    Campy Vento Reaction wheelset
    Building up a new De Rosa frameset and have decided to go with Chorus on this one... Also thought I'd go with a pair of Zonda's... but the Vento Reaction wheelset has caught my eye as a way to shave a few bucks off the project. They are heavier than the Zonda's (1,827g vs 1,580) but I can deal with that for training/commuting. Interesting front spoke pattern.
    I've seen reports claiming that it's crazy impossible to mount or remove a tire from this rim.... and fighting a rim to fix a flat when running late for work can ruin a morning.... but these reports seem to be on the older 'Vento' model.
    Any experience to share on the Vento Reactions? Would this be a significant step down in quality/performance from the Zonda's?
    TIA
    Twitterpated
    Reputation: T-shirt's Avatar
    Aug 2004
    I've used Eurus's and Neutron's. Both alloy wheelsets proved hard for me to mount tires. So maybe it's a common trait among Campy alloy wheels. Great wheels but I dread getting a flat.
    AM999's Liberal Facist
    Reputation: Marc's Avatar
    Jan 2005
    Quote Originally Posted by T-shirt
    Depends on the tires.
    Miche tires are impossible to mount without lots of muscle and tire levers
    Bontrager tires will slip on with only your hands.
    IME.
    Man. You are all stuped.
    ~RUFUSPHOTO
    Jul 2010
    Good insights! Hmmm... no experience with Bonragers. I'll take a look at their lineup. I've been running Conti Gatorskins on the commute w/ great results (knock on wood), but I've been told these can run a bit small. Also been tipped to use a generous amount of talc next time.... which hopefully won't be today!
    Nov 2006
    Quote Originally Posted by Marc
    IME.
    +1
    Continental and Panaracer mount easily on both my Zondas and Eurus 2way-fit.
    Vittoria are a pain to mount.
    Reputation: Barry Muzzin's Avatar
    Sep 2006
    Vredesteins...
    mount like butter.
    classiquesklassieker
    Reputation: orange_julius's Avatar
    Jan 2003
    Quote Originally Posted by cyclostf
    +1
    Michelin Pro 3 tires are a pain on my Neutron ...
    I have a set of Shamals coming, let's see how bad they are.
    Apr 2005
    All campy wheels are hard to mount tires on. The worst tires are Vittoria. Michelin's tend to be bad too. Schwalbe and Vred are good. The hardest tire I ever had to put on a Campy wheels was a Bontrager, but it was a wire bead so that may have more to do with the issue. Conti's are middle of the road it seems. I have no instant memory of having to put them on a Campy rim, so that must mean it was fairly painless to do.
    Vittorias are only hard to get on the first time. Once they are on they go on and off pretty easily so don't worry about having to change a flat.
    Reputation: Pirx's Avatar
    Aug 2009
    Quote Originally Posted by orange_julius
    I have those tires on Campy Shamals. Mounting them by hand only may be hard for some, but they do not pose any particular problems when using levers. Not bad at all in my book.
    P.S.: Oh, and the Shamal are absolutely awesome wheels. Among the very best wheels you can get at that price point, bar none. I continue to be surprised how few of them are out there. In particular compared to Ksyriums which are not even in the same league as the Shamal.
    Jan 2003
    Quote Originally Posted by Pirx
    Thanks for the info, Pirx.
    Do you run your Shamals as tubeless or as regular clinchers? I was eye-ing a set of Fulcrum Zero 2-way wheels, but I was able to get the Shamal for a nontrivial difference.
    I also do not know why those Ksyriums are so popular. Was it the Lance effect? It seems with the Ksyriums you really get the worst of all worlds.
    Aug 2009
    I got the regular, not two-way ones. When I bought mine, the people I talked to were quite negative about the idea of tubeless tires. It seems you absolutely need to have some leak-stopping gunk sloshing around in in your tires to make them airtight at all. I am not sure if that is true, but the other big turn-off for me was that there was, and still is, only one single supplier of tubeless tires.
    Exactly.
    Apr 2005
    I have a set of Two-way Shamals. I have used tubeless and regular tires on them. You don't "have" to use sealant, but why would you not. It only adds a bit of weight, and it works like a hot damn. I personally prefer the tubeless. I run them @ 80 front and 85rear. Smoother than my 320tpi 24c Pave's @ 90psi.
    And I agree. They are the best alloy wheel on the market.
    Jan 2003
    Quote Originally Posted by mtbbmet
    I've heard this comment about "tire goop" from a friend, it makes sense to use them if one were to run tubeless.
    Great to hear about your experience comparing tubeless vs. Vittoria Paves. That's exactly what I'm looking for: more riding comfort but without sacrificing wheel reactivity.
    Can't wait to get my Shamals!
    all the gear - no idea
    Sep 2003
    zonda
    Quote Originally Posted by redmasi
    TIA
    Those G3 lacing patterns in front are not ideal IMO (uneven stresses to rim) (good in back) .
    My Zondas have been excellent and bombproof.
    My Khamsins with G3 in front are good and tough as workaday wheels but I have my doubts about G3 in front - and so may Campy, as new 2011 Khamsins are radially spoked in front.
    Nov 2008
    From what I understand Campagnolo has done a bit of redesign on the rim beads for 2013 so that tires can mount easier.
    I just bought a set of the but the bike shop installed them
    Fai Mao
    A Proud Retrogrouch
    Trek Rental Agent
    Reputation: FatGut1's Avatar
    Dec 2008
    Have a pair of Vento Reactions. Agreed that the Vittoria's are tougher to mount but they are great wheels. Sure, heavier than my Eurus wheels but they are a solid wheel. I have only broken one spoke at 9000k miles a year.
    Nov 2008
    I think that Campagnolo revised the rim seat in 2012.
    I have not had any problems mounting tires on Vento Reaction wheels
    Fai Mao
    A Proud Retrogrouch
Sea Otter Classic
Contest
