Results 1 to 5 of 5
    Jun 2017
    ird campy cassette 11-28 or 11-30 with stock Record derailleur?
    Will the Record rear derailleur work with either the 11-28 or 11-30 IRD cassettes? The current rear cassette is a 13-26 9 speed.
    I converted my wife's road bike to a flat bar using the Campy Ergo flat bar 10 speed shifter setup last year. I'm looking for a slightly wider gear spread.
    Thanks.
    Jun 2017
    Change that to the Campy Centaur 10 speed road 12-30.
    Reputation: David Loving's Avatar
    Jun 2008
    Waxahachie, Texas
    Biciclette Gios
    "Forget it, Jake. It's Chinatown."
    Jan 2010
    It should "work" in terms of clearance. You will likely need to adjust the "H" screw.
    What DL is pointing out is that it may be marginal for the full range of gearing because the Record RD is limited to a total takeup of 32-33T.
    12-30 takes up 18, leaving 15T difference for the chainrings. Therefore a 50-34 combo with a 16T difference will put the system slightly over.
    You just have to be very careful in chain sizing to make sure the big-big is OK.
    There's sometimes a buggy.
    One.
    Jun 2017
    Up and running.
    Thanks for the help.
  1. Campy Record 11 vs Campy Super Record 11
    By NorCalBiker in forum Campagnolo
    Last Post: 12-27-2009, 06:38 AM
  2. Campy Record 10 or Campy Record 11?
    By flyingtiger in forum General Cycling Discussion
    Last Post: 11-20-2008, 11:54 AM
  3. IRD 11x30 Cassette with Dura Ace 10 speed rear derailleur
    By JTTucker in forum General Cycling Discussion
    Last Post: 08-20-2008, 11:40 AM
  4. IRD or FSA Compact Derailleur
    By Carbonman in forum Components, Wrenching
    Last Post: 02-13-2006, 08:47 PM
  5. IRD making compact crank front derailleur
    By spookyload in forum Components, Wrenching
    Last Post: 02-02-2005, 07:04 AM
