Blacklisted
Jagwire cableset w/ 11-speed?
Does anyone here have any experience using the Jagwire kits with 11-speed? I'm in need of a cable and housing kit and was thinking of trying one of these: http://jagwireusa.com/index.php/prod...ad/cable_kits/ rather than the Campagnolo kit for a splash of color. Any input appreciated!
info..
Jagwire did not work for me when I tried it. I have had success with Shimano housing and Campy cable, on the right side (RD).
my experience
I've used the Jagwire housing w/ 10 speed, both the older Ergo Power & the current Ultra Shift. Shifting w/ the Ergo Powers is fine (in this case I give a big YMMV, as others have not been so fortunate); with my Centuar 10sp UltraShifts, the Jagwire helped create a shifting nightmare.
I'd imagine the 11speed would be at the very least comparable to my 10sp UltraShifts, if not a bit more sensitive to "other brand" housings. I'd say stick w/ Campy's stuff if at all possible.
Blacklisted
Thank you both for your advice. Sticking with Campagnolo.
- You may not post replies
- You may not edit your posts
Forum Rules
