Results 1 to 2 of 2
    Jan 2010
    Re using Scirrocco hub from A G3 laced wheel
    I have/had a set of Scirroco H35 wheels which have the rear G3 pattern I barely used but really llke them.
    My son broke ,as in snapped, two spokes in the G3 pattern.
    Given that spokes to my knowledge cant be bought singulary and then ,from what I read online, rebuilding the G3 wheel can be difficult I was thinking of scrapping the rim and reusing the hub for a anew build on a standard rim.
    Is the hub G3 specific as well?
    tka
    tka is offline
    Jun 2014
    You can get either the Scirocco 04 mini kit KIT-500SC or the Scirocco 35 mini kit WH-018SCC. Each kit contains 2 front, 2 right rear, and 2 left rear spokes along with new nipples. They're about $25 for the kit. Your LBS can order them from QBP.
  1. All radial laced disc wheel....
    By robt57 in forum Wheels and Tires
    Last Post: 06-20-2015, 06:58 AM
  2. Problem with radial laced front wheel
    By jaxxon in forum Wheels and Tires
    Last Post: 05-22-2009, 08:16 AM
  3. Wheel repaired with re-laced hub
    By kai-ming in forum Wheels and Tires
    Last Post: 11-15-2007, 04:36 AM
  4. Never seen a wheel laced like this before???
    By handsomerob in forum Components, Wrenching
    Last Post: 04-24-2007, 12:55 PM
  5. Radial laced Wheel, Spoke Tension?
    By Angular in forum Components, Wrenching
    Last Post: 09-29-2004, 06:17 AM
